S2000 STR prep resource
Originally Posted by PilotSH,Jan 13 2010, 03:31 AM
snip...
Other good choices besides the Toyo R1R and the Bridgestone RE-11s are:
Yokohama AD08
Hankook RS3s
Dunlop Z1 SS
Kumho Ecsta XS
snip...
Yokohama AD08
Hankook RS3s
Dunlop Z1 SS
Kumho Ecsta XS
snip...
I will likely go RS3 or Dunlop to start.
From what I can tell 200+ runs is common with shaved street tires.
Originally Posted by Orthonormal,Jan 14 2010, 12:09 AM
Oh, really? My Dunlops must be special, then.
So are you getting good wear with no tearing of the edge of the tread blocks? I would think that shaving would provide additional stability and crisper turn in.
Originally Posted by TheNick,Jan 14 2010, 07:47 AM
Azenis 615-K
Same tread pattern, slightly different construction and compound.
Since I have no experience with the aforementioned upper spring mounts, I have a question. Let me preface that it is based upon my assumption the perch transmits load through a shock's upper mount to allow angular misalignment of the spring and shock together.
For those using the Koni, or similar, upper spring perches with the OE 'top hats', and possibly the GC units, are you concerned with spring's new load path? I would think the additional load on the lower shock rubber would cause significant compression, possibly limiting efficacy of the misalignment motion. I would also expect rapid wear and/or destruction of the rubber.
A cross section of a NB Miata 'top hat', which seems similar in construction to the S2000's (Majestic Honda exploded diagram for reference), is shown below with the spring's load paths represented by black lines.
Feel free to point out my errors as I have no experience with types of setups.
New load path left, OE load path right with the OE spring position as the red dots (this does not depict the OE upper spring rubber thing):
Exploded shock mount diagram (front):
You read all those posts a little ways back up this thread that discuss this very thing right? Bottom line: nobody knows the difference between coaxial spring compression vs. misaligned compressed as illustrated above because the user felt difference will be minimal. It would be theoretically ideal to have a separate upper spring perch that is not part of the top hat but I don't think it's gonna cost anyone any time on course.
