S2000 STR prep resource
Old Aug 7, 2009 | 04:27 PM
  #101
bronxbomber252's Avatar
I think you could Only remove it to install a aftermarket one... if you got an aftermarket one and wrapped it I think you are OK but I agree that it is gray
Old Aug 7, 2009 | 04:49 PM
  #102
TheNick's Avatar
There is nothing to say you can't wrap a header. Don't know why you would want to though - just makes the header crack sooner.
I have never ever seen a heat shield on an ST Civic and there is one on the stock manifold. That being said - I've never looked at the one on the S. Does it attach the body or directly to the header?
Old Aug 7, 2009 | 04:52 PM
  #103
TheNick's Avatar
The rule referenced on the previous page is talking about "exhaust heat shields' which to me means body heat shields - the S doesn't have any of these as far as I know - maybe just above the cat.
On many cars - there are metal shields bolted to the body in the exhaust tunnels.
AFAIC - the heat shield that is attached directly to the manifold is an integral part of it and replacement of the manifold with an aftermarket header does not require a heat shield.
Old Aug 7, 2009 | 05:35 PM
  #104
User 121020's Avatar
True, heat wrap does wear out the header quicker. Been there done that. However, wrapping significantly lowers under hood temps, from what I've experienced. Between dyno runs I lost about 10 whp with the OEM setup, so I'm just trying to find ways to combat heat within STR allowances.
The heat shield in question is only attached to the OEM header. I'd like to remove it and try to wrap the OEM header. With how cheap OEM headers can be purchased in the classifieds, maybe it would be worth it to tolerate the accelerated wear in order to decrease temps. Just thinking out load.
Old Aug 14, 2009 | 11:40 AM
  #105
scareyourpassenger's Avatar
[QUOTE=angryfist,Jul 28 2009, 04:52 AM] Go back and read the rulebook again. Its not as simple as just allowing any "piggyback" unit.
14.10.F.2: Electronic components may be installed in-line between an
engine
Old Aug 17, 2009 | 07:32 AM
  #106
TheNick, I snagged this quote of yours from a different thread in the R&C forum. Maybe you could elaborate a bit more?
I haven't given up on Megasquirt though. Thats the only option the 00-05's have to get some decent power although things aren't looking so good with OBD2...
I had been thinking about trying to cram a MicroSquirt Module into the stock AP1 ECU case. It would take some amount of testing to determine how best to keep OBD2 happy. Just a thought....
Old Aug 17, 2009 | 09:23 AM
  #107
TheNick's Avatar
My original thoughts were the MS in parallel too. But from what I understand - there isn't enough room to do it inside the box. Then you'd also have to figure out a way to keep the feedback loop intact for the injectors and ignition without using dummy resistors. That is way over my head - I'm not an electronics guy - I'm a 3phase power guy.
edit - I've also been told that the MS doesn't support the stock cam/crank sensors.
Old Aug 25, 2009 | 07:37 AM
  #108
TheNick's Avatar
Anyone have any experience with some lightweight pillowball upper mounts/top hats?
Had the car on the scales last night and was pleasantly surprised. So I'm starting to drum up solutions to all the "loose ends" for next year. The stock upper top hats are pretty heavy - so I'm looking from some lighter aluminum ones.
The only ones I seem to be able to find are the Tein's - but all the pictures I've found on Google are for the MacStrut versions that are camber plates.
Old Aug 25, 2009 | 11:05 PM
  #109
mLeach's Avatar
tein makes a pillowball mount, and AST does too.
Old Aug 26, 2009 | 04:54 AM
  #110
BrianGT's Avatar
Motons come with them
