S2000 STR prep resource
Are people really doing 8800 RPM with the flashpro? I thought it was more like 8500. 8500 is not too bad. I did the calculations. Here are my notes:
AP1 @ stock cutoff 9000 RPM
Max Piston Speed ft/s: 8331
Max Piston acceleration positive/negative (g): 2906 / -5019
AP2 @ stock cutoff 8200 RPM
Max Piston Speed ft/s: 8016
Max Piston acceleration positive/negative (g): 2504 / -4446
AP2 @ 8500 RPM
Max Piston Speed ft/s: 8310
Max Piston acceleration positive/negative (g): 2690 / -4777
AP2 @ 8800 RPM
Max Piston Speed ft/s: 8603
Max Piston acceleration positive/negative (g): 2883 / -5120
So at 8500 RPM, I feel moderately OK with it, since the max piston speed is about the same and the max piston acceleration is actually less. But at 8800 RPM, you're upping maximum speed by 3-3.5% compared to the AP1 - which was already a very high speed. Plus it worries me that they gave themselves so much extra wiggle room on the AP2 - I'm not sure why they did that? Can it not handle the same forces?
Also, none of this takes into account floating valves or anything like that, since that would depend on the camshaft profile. Anyone have any idea if the camshaft profile is significantly different between AP1 and AP2?
I'm really, really hoping this class doesn't get to the point where it's either engine reliability or competitiveness.
AP2 @ 8500 RPM
AP2 @ 8800 RPM
Originally Posted by ///MIKE,Sep 21 2010, 02:58 PM
What's the consensus on this? I don't want to be blowing up my 05 AP2 just to get a couple more MPH out of 2nd gear.
How would it be different than a 06+ getting flashpro and going up to 8800 rpms? My "understanding" is that the AP1's are rev-limited to 8800 rpm's as well.
I do have a shift beeper... but I am not going to catch it everytime... I know I'll mess up sooner or later.
Originally Posted by ///MIKE,Sep 21 2010, 08:57 AM
If I remember correctly... Jim had pretty phenominal dyno #'s on his 200k mile AP1.
I'd give anything to have the gearing of an AP1 after nationals... However, I did just find out that I can throw an AP1 ecu in my 2005 AP2. Good news because I'd thought I was the "odd one out" up until now.
Honestly I think my nationals results were mainly a function of how well my car was handling at that site. I run A LOT of front bar, really low, the rear wing helped, and the hankooks worked great. I didn’t drive out-of-my-mind, I just setup the car to where it’s boarderline boring and easy to drive fast.
Clearly I think the AP1s are competitive and will continue to run mine because I’m not interested in making car payments at pretty much any point in my life. So if you’re shopping for an STR S2000 and have a tight budget, get any AP1 (02-03 will be a little heavier but so what). But if you want to spend lots of money get an 06+ or a CR. Until the ECU rules change the main ones I’d stay away from are the 04-05, but the AP1 ECU trick may work there.
Originally Posted by Jreyenga,Sep 21 2010, 03:42 PM
I think this is a matter of the grass is greener on the other side. FWIW, my dyno numbers I posted up were measured on a dynopak at the hubs, which reads substantially higher than at the tires. Peak power was 224hp (227 with the hood left open, but I’m not interested in autocrossing with the hood open), which is 26hp down on the 06+ AP2s on the same dyno with similar mods and a flashed ecu. I used 1st gear once on each course, and I assume the AP2 guys did too. Maybe Nick or Matt can chime in, but with the raised limiter, I don’t believe 3rd gear was a big issue for the reflashed cars.
Also, is the 02-03 AP1 that much heavier? I thought it was like 25 lbs?
Jon, Interested numbers with the piston velocity and accelerations. Either way, 8800 rpm scares the crap out of me in an AP2. The stock AP1 piston velocities are actually above an F1 engine, iirc.
If I ran a reflashed AP2 I'd probably get in the habbit of changing rod bearings once a season just for peace of mind. They're cheap and it's really really easy (especially after you know what sizes you need). Like... $50 or so from HPD.
Originally Posted by Jreyenga,Sep 21 2010, 03:49 PM
no sweat, I went full open-komono after nationals on the car. https://www.s2ki.com/forums/index.php?showtopic=816603
but the thread got bumped down a page
edit: wait a minute, you replied to me on that thread! is the image I attached not loading?
Thanks!
