S2000 STR prep resource
Old Feb 10, 2010 | 09:05 AM
  #1171
whitt1's Avatar
You could have the lobe wielded and reground if you have a good local cam grinder. wielded lobes are stronger than stock.
Old Feb 10, 2010 | 10:01 AM
  #1172
TheNick's Avatar
Anyone else see something wrong with the upper mount on the shocks or is it just me?
Old Feb 10, 2010 | 10:05 AM
  #1173
glagola1's Avatar
let's hope you can close your hood!
Old Feb 10, 2010 | 10:06 AM
  #1174
GEARHEAD's Avatar
Originally Posted by TheNick,Feb 9 2010, 01:06 PM
Do yourself a favor and do two step shim stacks. One shim stack for low speed - then a spacer - then your smaller stack for mid-high speed damping. DO NOT USE ANY PRELOAD. Try it out and see what happens.
You don't need a whole lot of rebound, but I would try the double digressive piston if I were you - you need SOME low speed rebound and right now you don't have any at all with the linear rebound. When you added more rear rebound - you added a ton of high speed damping that will cause the inside tire to skip over the surface. This can cause some goofy handling characteristics.
Your rebound adjuster only touches the bleed through a jet in the shaft. You can replace the jet to get different low speed characteristics as well. I don't think you can mess with the 8100 canister much - you'll just need to put thicker shims on the compression side.
I agree, a double digressive piston would be a better option. However, I'm curious about your Preload comment. Why not use "ANY PRELOAD"? I'm not intimately familiar with Penske's double digressive piston but if it's like others I've used, it has a lot of low speed damping and perhaps using a preloaded shim stack would be too much. This assumes you were referencing compression and not the linear rebound side.
What about using a preloaded stack on the rebound side to get some digressive behavior?
Old Feb 10, 2010 | 10:18 AM
  #1175
TheNick's Avatar
Bottom of Page 45:
They then use multiple levels of shim stacks with spacers and very low preload. They use thicker shims to get the high speed damping, instead of preloading thinner shims. The shims have a progressive spring rate, if you preload them - they lose the initial soft spring rate and go straight to the harsher rate. When you blow off at the knee of the curve, the shims snap open very quickly. By using thicker shims and low preload - the initial soft spring rate is still preserved and the transition is much smoother.
Works for Moton - why wouldn't it work for Penske too?
Old Feb 10, 2010 | 10:20 AM
  #1176
glagola1's Avatar
I think Nicks comment about preloading may have to due with the nature of steel spring and how it behaves when preloaded. Something about having an abrupt operation when preloaded which will cause pressure drops on the back side of the valve and erratic behavior on the edge of it's operating realm.
In other words, it will cause a funky transition between high and low speed.
Old Feb 10, 2010 | 02:18 PM
  #1177
angryfist's Avatar
Fox Racing remote canister?? What did those come off of?
Old Feb 10, 2010 | 04:10 PM
  #1178
TheNick's Avatar
A snowmobile or something
I've got 4 more that are longer and meant for a car that someone gave me this past weekend.
Old Feb 10, 2010 | 04:49 PM
  #1179
alvanderp's Avatar
I can't tell if the adapter is longer than mine or if there are just more threads on it. Did you try and install the OE topmount yet?
I can't find any pics of mine with the adapter installed on them. The 2nd pic you posted looks more normal to me, maybe it's the scale of the first pic.
Old Feb 10, 2010 | 05:05 PM
  #1180
TheNick's Avatar
The adapter is quite long. And I haven't tried the OE Top Mount yet. That will be tomorrow.
