S2000 STR prep resource
Old Jun 30, 2010 | 09:48 AM
  #2171
Voodoo_S2K's Avatar
Originally Posted by josh7owens,Jun 30 2010, 10:37 AM
What'd the wink face mean? Is that a yes or a "what a noob question"
It mean go with what I quoted.
  #2172
chetly's Avatar
The wink was a yes. If you disconnect both endlink the bar would fall down onto the drive shafts. I actually take the link off so it doesn't flop around and bend stuff.
Old Jun 30, 2010 | 09:51 AM
  #2173
glagola1's Avatar
Originally Posted by Jreyenga,Jun 30 2010, 12:35 PM
FYI, do not turn into a steeply ramped driveway. My passenger fender is currently “non-compliant” due to having the inside wheel in a sharp turn support the whole weight of the front end. Also took a big chunk out of the tire as it grabbed a fender tab and completely bent it to where it was pointed out of the fender.
No kidding. At an event early this year, there was a dip on a turning braking zone and I took a big ole chunk out of my tire and bent up my driver side fender pretty good. I bent everything back with a vise grip and some wood but it ain't pretty.
Moral of the story is: roll your fenders and especially those damn fender liner tabs or you too will catch a tire one day.
Old Jun 30, 2010 | 09:58 AM
  #2174
User 121020's Avatar
Originally Posted by josh7owens,Jun 30 2010, 11:37 AM
Dave seems to run a tad toe out in the front on his car and seems to like it. From going from stock to my alimment now is a crazy difference. It seems I get better turn in and rotation with a tad bit of toe out in the front and a small bit of toe in in the back.
The change in rotation is probably your rear toe setting and running a non-staggered setup. 0.28" of total toe out in the front is high, in my opinion. Is it a handful to keep pointed in a straight line at highway speeds?
I will say that I had a good A-stock season with an 1/8" of total toe out in the front. I haven't been able to feel the difference between an 1/8" total toe out and zero front toe, which is why I made my earlier statement.
Old Jun 30, 2010 | 10:15 AM
  #2175
josh7owens's Avatar
Ok thanks, I took the link off and leftthe other side.
Nick what are your alimment specs right Noe with no rear bar? Sorry for all the questions
Old Jun 30, 2010 | 10:27 AM
  #2176
TheNick's Avatar
I have no idea what an alimment is.
Old Jun 30, 2010 | 10:32 AM
  #2177
imstimpy's Avatar
Originally Posted by TheNick,Apr 22 2010, 06:38 PM
2.2deg in the rear.
Current Setup is
Front
900lb springs
2.7deg camber
0 Toe
9deg of caster
1-3/16" 37.5" Hollow Front bar
Rear
700lb springs
2.2deg camber
.1 toe in per side (1/16" total)
Tire Pressure on the Dunlops was 38F/32R - same we ran on the RE-11's last year.
I think the lack of rear bar is allowing more load transfer onto the outside front instead of sending to the outside rear. This is hitting a sweet spot on the load vs grip plot of the tire.
Don't believe him !
Old Jun 30, 2010 | 10:34 AM
  #2178
imstimpy's Avatar
Does the rolling prevent using some of the fender liner clips? I looked briefly but the fender liner was in the way.
Old Jun 30, 2010 | 10:44 AM
  #2179
Josh, are your alignment toe specs are in degrees or inches? I assumed you were using inches, but your alignment would make a lot more sense if it was in degrees. I guess that's what I get for assuming....
Old Jun 30, 2010 | 11:13 AM
  #2180
glagola1's Avatar
Yep. The clips are gone. The liner stays in just fine albeit with several areas rubbed away by the tires.
