S2000 STR prep resource
Old Mar 19, 2010 | 05:03 AM
  #1501
Random1's Avatar
The biggest thing is probably the difference between front and rear spring rates. The FSB may also be contributing.
-3 deg camber in the rear may be too much for the Star Specs. I reduced from -3 to -2 and it feels better, but need more time as that was run for just one event. Rear toe is a personal choice. You will see it range from -.25 to 0 depending on the person. I think spec for an AP2 is -1/8.
Old Mar 19, 2010 | 05:13 AM
  #1502
TheNick's Avatar
Spring rates are too low for the rear and WAY TOO MUCH rear camber. You don't need more than 2.2-2.3 deg.
  #1503
TheNick's Avatar
Originally Posted by angryfist,Mar 19 2010, 07:04 AM
dont tell me this. going to the dyno in 2 weeks.
You might be ok - what year ECU did you get?
Old Mar 19, 2010 | 05:38 AM
  #1504
angryfist's Avatar
-A02 (02-03) the lean one...
We'll see what happens i guess...
Old Mar 19, 2010 | 05:40 AM
  #1505
Miatamoto's Avatar
Great info guys! Thanks for the help.
On a side note I did a side by side visual comparison between a 25540 Toyo R1R (17x9 wheel) next to my 24540 Dunlop on my 17x9s for the MX-5 and they were very similar in width.
Old Mar 19, 2010 | 05:43 AM
  #1506
TheNick's Avatar
Mine ran for the entire season last year with AFR's in the high 14's at WOT and I never had any issues. Spark plugs looked perfectly fine. I wouldn't worry about it - just don't get too greedy with the VAFC.
Old Mar 19, 2010 | 06:14 AM
  #1507
angryfist's Avatar
Nick, did you hook up the VTM wire on the VAFCII? I got this hacked up harness (that is supposedly for a VAFCII) that i'm reassembling and it has the VTM wire connected to the VACFII. The APEX-i diagram doesn't show this hooked up. I'm wondering if i need to disconnect it from the VAFCII and reconnect it to the ECU.
Old Mar 19, 2010 | 06:35 AM
  #1508
TheNick's Avatar
I don't remember - I seem to remember the only two wires I didn't hook up were the TDC and VTC wires...but maybe thats why I had issues.
Old Mar 19, 2010 | 06:40 AM
  #1509
bronxbomber252's Avatar
on star specs I have been happy with 700/600 spring rates on stock 01 bars... very balanced. i know glagola and nick run bigger bars up front and stiffer front springs than me... I think its a lot of driver preference
Old Mar 19, 2010 | 06:42 AM
  #1510
TheNick's Avatar
Thats sorta true but not really. Some things have changed in the past month or so.
