S2000 STR prep resource
Old Mar 19, 2010 | 08:09 AM
  #1511
daverx7's Avatar
Originally Posted by TheNick,Mar 18 2010, 10:04 PM
Whistles innocently....
Congrats Nick! Nicely done!
-D
Old Mar 19, 2010 | 08:16 AM
  #1512
daverx7's Avatar
In choosing my spring rates, I thought I would model the F/R ratio after the CR and go close to the limits of my TC Klines Koni DA's.
CR = 392F/342R
Max = 700F/610R (600 close enough)
1 notch lower = 650F/567R (550 close enough)
The initial setting that the TC Kline rep suggested was 400F/500R... that seemed opposite from this thread though
My tech suggests to go a little conservative, by going with: 650/500.
I believe I am going to go with my tech's suggestion and work from that.
Thoughts?
-D
Old Mar 19, 2010 | 08:26 AM
  #1513
robinson's Avatar
Two things.
Try less rear camber, and/or more rear spring. I bet your natural frequency's are too far apart with 250 lbs between the front and the rear. I have 800/700 and the NF is about .2 to .3 apart.
Keep in mind, my NF calculations are not 100% accurate, but probably close enough.
Old Mar 19, 2010 | 08:40 AM
  #1514
daverx7's Avatar
CR = 392F/342R
Thoughts?
-D
Just got the call from TC Kline, so I ordered the goodies with the springs being 650F/500R.
I'll search the thread for ride height recommendations.... hope it is working today. LOL
-Dave
Old Mar 19, 2010 | 08:43 AM
  #1515
TheNick's Avatar
Center of hub to fender 13-13.25 front. Make the rear .25" higher.
That should be ok with soft spring rates.
Old Mar 19, 2010 | 08:47 AM
  #1516
daverx7's Avatar
I really appreciate you sharing your knowledge. I understand that these are all just starting points and will need to adapt to driving style and setup.
Thanks again!!
-Dave
Old Mar 19, 2010 | 09:54 AM
  #1517
robinson's Avatar
I'll get you mine final ride height this weekend. Keep in mind I have stiffer springs.
Old Mar 19, 2010 | 10:00 AM
  #1518
BrianGT's Avatar
We run similar with softer springs:
13" front center of hub to fender, 13.25 rear.
450F 550R spring rates
Old Mar 19, 2010 | 01:19 PM
  #1519
daverx7's Avatar
Interesting that you are just a hair higher than what TC Kline recommended and having the fronts softer than the rears.
Sooo... how do you like how the car feels with the current rates?
-Dave
Old Mar 19, 2010 | 01:24 PM
  #1520
glagola1's Avatar
I have 700 and 850 springs and my car is too rolly.
