S2000 STR prep resource
Old Sep 13, 2009 | 07:43 PM
  #181
IMP's Avatar
IMP
Just trying to help some people understand a simple rule. (And yes... it's gonna be a crazy winter methinks).
--kC
Old Sep 14, 2009 | 07:54 PM
  #182
whitt1's Avatar
I'm new to this forum.but a long time autocrosser planning to build a STR S2000.My observation is that everyone that has run a stock class S2000 has been running a huge front swaybar to compensate for a weak limited slip and oversteer.My thought woulld be to go with hard rubber mounts and bushings for the differential,engine and transmission to locate the drivetrain.Add all legal means to stiffin the body, front and rear upper and lower strut bars.Then go with a shock and spring package that addresses the car's oversteer and turn in and use a more moderate sway bar package then address the car's traction issues with a true limited slip.
Old Sep 15, 2009 | 09:59 AM
  #183
dnace's Avatar
Ok before I ask this know that I am not trying to max out to win this class. But I like the idea that I can fit into a street tire class and still have a safe car for HPDEs.
I have not gone with a rollbar/seat setup for the last year due to the seat and interior removal limitations in AS.
My question: If I get a hard dog roll bar what interior modification can I do? Can I take out what I want be hind the front seat? Do I still need to retain stock interior but can trim to make the bar fit? Anything else that this may cause a problem for the STR class? Thanks for the help!
Old Sep 15, 2009 | 12:02 PM
  #184
whitt1's Avatar
I believe the Gendron roll bar you are referring to is actually a swaybar instead of roll over protection.SCCA approved rollbars approved for showroom stock competition should be available from several sources but would do little to help in solo competition accept to allow you the use of a racing harness.Most require little modifacation of the interior and do look kind of cool.
Old Sep 15, 2009 | 12:30 PM
  #185
dnace's Avatar
lol nope I had something on the mind I meant I plan to get a hard dog roll bar.
Old Sep 15, 2009 | 03:01 PM
  #186
iLuveketchup's Avatar
Forgive me if I missed it, but removal of the soft top is not allowed under STR classifications.. Correct?
Old Sep 15, 2009 | 03:03 PM
  #187
BrianGT's Avatar
no, the only way you can have a car without a sunroof is to buy a CR
Old Sep 15, 2009 | 03:50 PM
  #188
Thanks.
Old Sep 16, 2009 | 09:11 AM
  #189
dnace's Avatar
so how much interior modification is allowed? I am assuming I can't take the factory roll hoops out? Can I take some of that plastic trim and hidden compartment? I though all the STS civics were stripped in the rear.
Old Sep 16, 2009 | 09:21 AM
  #190
TheNick's Avatar
No interior modification is allowed. Only that which allows the installation of a roll bar/cage. There are no ST cars with stripped rears.
