S2000 STR prep resource
Old Jun 14, 2010 | 08:52 AM
  #2061
scareyourpassenger's Avatar
Originally Posted by marks_lude,Jun 13 2010, 06:19 PM
Is anyone getting away with the hollow gendron bar?
I have 650/600 f/r spring rates and the hollow bar on full stiff and it feels like a lot of body roll. I'm considering going back to the solid bar... but that sucker is heavy.
I am running a .25 hollow with great results.
Old Jun 14, 2010 | 09:56 AM
  #2062
glagola1's Avatar
Me too. It seems to go a little stiffer than the comptech at full stiff so that's pretty cool. The ball bearing mounts are pretty nifty too.
Old Jun 14, 2010 | 09:58 AM
  #2063
glagola1's Avatar
Static RC height isn't all that much affected by lowering the car. When I modeled the geometry I found that I'd have to raise the car over 2" to get 1/2" RC change. That just isn't anything to worry about. It's generally low height is how ever a good reason to run big sway bars on this car.
Old Jun 14, 2010 | 11:16 AM
  #2064
marks_lude's Avatar
Originally Posted by robinson,Jun 13 2010, 11:42 PM
The springs are a bit on the soft side if you want no body roll. However, body roll does not mean bad handling. What you want and what your car does are different in this situation, and if your car is easy to drive and is well balanced, then I would not change anything. Don't change your car for change sake.
I think there might be some placebo effect going on in my mind. First 2 events were cold and low grip. Did a warm TnT and was left thinking "what the heck".
The desire to change was to try to find a way to get the rear bar off. As others had reported, there is a pretty clear improvement on when you can put power down (spent the morning of the TnT with no rear bar), but obviously the roll increases.
The solution would be to stop DDing this car so I can justify higher spring rates
Old Jun 15, 2010 | 05:55 PM
  #2065
marcrx5's Avatar
It looks like I'm going to run helper springs in the rear, and I'm wondering if anyone has tried tender springs instead of just helper springs, to make sure the rear tires stay planted? Is rear inside wheel lift a non-issue with stiffer springs (ie STR vs Stock)?
Should I just run helper springs and forget about it?
Old Jun 15, 2010 | 05:57 PM
  #2066
robinson's Avatar
As far as I know, tender=helper. I have them on all corners, they get used slightly with 6 in springs, more if the swaybar is disconnected.
Old Jun 15, 2010 | 06:09 PM
  #2067
imstimpy's Avatar
With near stock ride heights, my Hyperco helpers and 7" springs have roughly a half inch of extension at full droop. They will get more necessary as I lower it.
The reason for helpers isn't just pressing the rear tire down but also so your rear spring stays seated and doesn't mash up your perch.
Old Jun 15, 2010 | 06:15 PM
  #2068
robinson's Avatar
The only reason for them is to keep the spring lined up. A 25 lb spring not doing anything with the tire.
  #2069
macr88's Avatar
Helper springs are only for keeping the spring seated. Tender springs provide some spring rate.
Old Jun 15, 2010 | 08:06 PM
  #2070
marcrx5's Avatar
This!
Tender springs could be 100 lbs or so, just enought to make sure the rear tire is planted if the spring extends to free length (ie no force).
Is anyone anywhere near unseating the rear spring? If not, I think that answers my question.
