S2000 STR prep resource
Originally Posted by TheNick,Jun 29 2010, 10:53 AM
IMO they are not part of the hub. They are a bolt-on mount for the lower arm. Just because they have two bolts that attach it to the hub vs just one bolt through the arm doesn't make them anymore part of the hub than they are part of the lower arm.
Unofficially of course.
I do think that they fit in with the intent of camber kits. If someone protests something like this, they should be kicked in the nuts.
-Brian
whats the wieght of the 2000 rear sway bar with all the hardware also?
I'm going to do some test at the up coming autocross, Is all I need to do is disconnect one side of the sway bar link or do I need to disconnect them on both lower arms?
set up-
front
toe out- .14 each side
camber-2.4 each side
caster- 5.4ish
rear
toe in .1 each side
camber 2.1 each side
stock shocks (till winter I still dont't know what I'm going with)
SFR soild 1.25 front bar (on full stiff)
949 wheels and rs3 tires
input would be great
set up-
front
caster- 5.4ish
rear
toe in .1 each side
I've heard people say Ackerman isn't important but I can't imagine ut wouldn't be.
Is it just that our car with 0 toe is fine? I've always felt that when I went to 0 toe from slight toe out that I lost a tad bit of cornering grip in the front. I've yet to go back and try a bit of toe out.
Ah! I know, it's probably due to the fact the our car toes out under compression so we get a bit there.
Originally Posted by glagola1,Jun 29 2010, 08:43 AM
How about those fenders Brian? They are not in compliance with the rule... if you want to be legal and all.
Idk, I'm not a pro like you guys that why I come here for information. Dave seems to run a tad toe out in the front on his car and seems to like it. From going from stock to my alimment now is a crazy difference. It seems I get better turn in and rotation with a tad bit of toe out in the front and a small bit of toe in in the back.
What'd the wink face mean? Is that a yes or a "what a noob question"
Another question...
I'm makes out at 2.4 in the front with stock ride hieght and j's camber joints. Ands setting at 2.1 in the back. Do I need to go up some more in the back... Say 2.6 or so? Or would that lead to more tire wear an no more grip gained
Another question...
