S2000 STR prep resource
Originally Posted by misterwaterfallin,Jun 13 2010, 01:23 PM
Kind of a general question but what are you guys doing to settle the rear down a bit? I dont have double adjustables so thats not an option. I have 0 toe in the rear, but am tentative to add toe in in the rear.
I want to go from 225/255 to 255's all around, but adding more front grip will just make this problem worse.
But really, you will have to give us the rest of your setup before anyone can give you any workable ideas because at this point I am just shooting in the dark.
Is anyone getting away with the hollow gendron bar?
I have 650/600 f/r spring rates and the hollow bar on full stiff and it feels like a lot of body roll. I'm considering going back to the solid bar... but that sucker is heavy.
Originally Posted by ///MIKE,Jun 13 2010, 07:51 PM
I thought the hollow was stiffer? Hmm.. I don't know how that makes sense... but anyway. I have a hollow and I have very little body roll. However, I'm running 14k front and 12k rear.
You'll need to provide your complete suspension/wheel/tire setup to get the best advice.
I just completed the first round install of my Motons. Other than no real good place to locate the rear canisters, I think everything went well.
I measured the factory ride height as follows:
LF 35.9cm RF 36.0cm
LR 36.9cm RR 37.3cm
First of all, is the RR typically off by a few mm from the factory? I didn't have a chance to put the car on the scales to check balance.
Other than a thread a lot of gross mis-information, I haven't found much on rake. I lowered the car equally'ish, front and rear.
Initial Moton ride-height:
LF 35.0 cm RF 35.0cm
LR 36.5cm RR 36.4cm
Does rake affect transitional stability much on S2000s? I can fine tune a BMW with rear ride height but a Subaru I cannot. My prior experience tells me I want the rear lowered at least as much as the front, if not more.
If anybody is curious, I'm starting at 700F/550R with no rear bar. I won't have any idea what I'll have to change until the 27th.
LF 35.9cm RF 36.0cm
LR 36.9cm RR 37.3cm
LR 36.5cm RR 36.4cm
Originally Posted by keifla123,Jun 7 2010, 03:42 PM
I will 2nd that. I weighed my 08 in stock class race trim. So lightweight wheels, exhaust cutout, spare and tool kit removed, but full tank of gas. It weighed 2776 at the Dixie Tour. On those same scales on the same day Marc's delete CR weighed 2700 even.
If I can run with half a tank of fuel instead of full the car will drop roughly 45 lbs going from stock to STR.
I was on lightweight wheels (TR/Kosei) on (4) 275/40/17 A6s, Corey's Exhaust mod, and full/topped off fuel tank. My car is usually around the upper mid-high 2600 mark in B-Stock trim.
Keith, were you on 245s? If so, thats worth 12lbs
Hate to see you leave BS, but will see you soon enough in STR.BTW, I ran 1/2 tank at the Blytheville NT on day 1 by accident. It was all 2nd gear without any shifting. No fuel starve. Seems the 1st gear downshifting is a major factor in fuel starving.
