S2000 STR prep resource
I just put 255 on my +63 6ULR's with stock suspension. I have not raced with this setup yet so I can't tell you about any suspension load related rubbing but I do know the wheel rubs on the lower control arm. Simple/small spacer will fix this.
Originally Posted by imstimpy,Jul 6 2010, 11:09 AM
Moton Clubsports
anti-roll bars F/R: stock/none
ride-height F/R: 34cm/34.5cm (13.39"/13.58")
springs F/R: 850#/750#, 7"x2.5" + helpers
toe F/R: 0"/3/16"
camber F/R: -1.8*/-2*
toe F/R: 0"/3/16"
To ensure similar balance I used a bunch of math to determine roll rates, calculated the bias in my current setup, then matched the front bar to the increased rate of the rear.
Moton Clubsports
anti-roll bars F/R: Gendron 1.25"x0.25"x36" @3/stock
ride-height F/R: 13.5"/13.25"
toe F/R: 0"/1/4"
camber F/R: -1.7*/-2.0*
We were scrubbing in a set of Dunlops on a dusty lot for the first few runs so it was a bit loose (yeah, yeah, only change one thing at a time). We pulled the front compression back a click during this time. After switching to a scrubbed set of Hankooks, the car drove exactly as it has before, albeit flatter. Back to the Dunlops on the now clean surface and the car had the same balance as the Hankooks.
Since the car is so stable on corner entry, our fastest line appears to start with trail-braking or pitching into the corner. With the right timing, the rotation continues with the transition into throttle (no drama). With the wrong timing, the rotation ceases and the car understeers into throttle.
You are going to start all over again once you get more front camber. Glad things are working well for you right now - will be fun to chat in Lincoln.
My car is almost a full inch lower than yours - albeit with the rear a touch higher than the front.
I haven't bothered going lower yet because I have some speed bumps and a wicked driveway to contend with. I've probably got another .25"-.5" more to go, but I haven't been able to quantify what it gets me.
Originally Posted by chetly,Aug 25 2010, 06:16 AM
has anyone measured the suspension geometry to see that if lowering the car to much would do more harm than good?
my car is nearly as low as nick's and i'm going to bring it down some more. the car feels amazing. there's only one way to find out! drop it and see how you like it.
dan
Originally Posted by ghostshadow,Aug 25 2010, 09:28 AM
i've read over and over that the benefits of low cg overweigh the drawbacks of less than ideal geometry (with the right setup). i don't think numbers on paper can determine if your car crosses the line in less time.
Originally Posted by ghostshadow,Aug 23 2010, 05:19 PM
you guys are right.. i'm not going to worry about it unless i get wheelspin. i'm really happy with it so far.. the car has no bad tendencies and is so easy to drive at the limits. i wasn't so sure how 1k all around would do but so far i like it. i do want a hair more steady state rotation and i think the less rear camber will be the ticket. besides the small tweaks, i'm itching for more dry seat time to take it all in and get used to the car. i'll have gj dixon and perry aidelbaum drive it to see what they think. they usually confirm what i feel and perry has a ton of time in an s2k.
only mods for me are big gendron, front camber (j's), and motons. we also left the hardtop on to stay dry (i've done back to back at a dry event and shaved a consistent 1/2 second by taking the top off!)
the conditions were so variable it was hard to compare to others.. but benchracing with my best rawtime, i was about 1 second off a fully prepped stu sti in pax (that ran in the same heat). the most time i can find will be in my driving. the car doesn't seem slow at all.
i think this pic shows how much grip the lot has! (looks like he needs less rear rebound too!)
dan
dan
-Jake
www.HamfistRacing.com
Anyone know a good way to remove the bushings from the rear upper control arms? I'm doing some last minute thrashing on the car before nationals. Because the rear bushings have an outer stop on them they have to be pressed from the inside-out. I might be able to figure it out with a vice, but certainly not my hydraulic press.
Also, turns out my ebay rear UCA balljoints look substantially different than stock, so they aren't going in...
