S2000 STR prep resource
Originally Posted by TheNick,May 25 2010, 06:23 AM
I'd rather be on RE-11's than Dunlops in the cold. In fact I'd rather be on anything other than the Dunlops no matter what the conditions are.
I've run RE-01Rs, AD07s and Star Specs on BMW E36 M3s; AD07s, AD08s, and Star Specs on a BMW E46 M3; and AD08s, RE-11s, and Star Specs on STIs/WRXs and the Star Specs were great on every platform.
The Star Specs are very precise, one of the most heat tolerant tires, have gradual break-away, and grip until they cord. Their cold performance makes for a wasted first run on RWD cars in temps below about 50*F, however.
Originally Posted by imstimpy,May 28 2010, 09:44 AM
Why the animosity towards Dunlops?
Wanna buy 'em? I've got 4 for sale.
Turn in was numb, car wouldn't turn mid corner and then from corner off the car wouldn't put power down when it should.
There's a chance that I completely missed the shock and alignment setup for them, but I know what should work and it wasn't happening on the Star Specs.
[QUOTE=macr88,May 26 2010, 09:38 AM]I couldn't find any info on the 8300 so I wasn't sure if it used the cd drum or preload on shim for the compression adjustment. So the 8300 uses the same shim type preload adjustment as the 8660 less highspeed or is it different?
The turn-in difference between a 245 on an 8" wheel vs a 9" wheel is astounding with the 8" being very sloppy. The 245s and 255s felt great on 9" wheels on E36 M3s (my closest experience to an S2000). My experience is all on struts with -3* camber (or more), could the extra static camber be the difference?
I considered Stones and Toyos to be sloppy whether they were on RWD or AWD cars. What tire did you prefer on turn-in alone?
