S2000 STR prep resource
Old Feb 11, 2011 | 08:45 PM
  #3381
PilotSH's Avatar
Well, after pestering Hankook tires for months, the new tire size is FINALLY here, and I'm the first to get a set!
I wouldn't call Tire Rack or DTD, as there were a limited amount of tires, and from what I heard there is only one retailer that actually has these. For those that don't know, the spec on these 245s are very interesting
James Yom
Old Feb 12, 2011 | 01:13 AM
  #3382
macr88's Avatar
James Yom
I don't know the specs but I do like the 255's on a 9 move a bit too much on the wheel than I like.
Old Feb 12, 2011 | 07:26 AM
  #3383
dnace's Avatar
I am super interested. Will you be running these side by side with a 255. I really want to know which is faster.
Old Feb 12, 2011 | 07:33 AM
  #3384
Random1's Avatar
The AWD STX and STU drivers are going to be very excited about these tires.
Old Feb 12, 2011 | 11:29 AM
  #3385
Zeus2k's Avatar
James Yom
care to elaborate?
Old Feb 12, 2011 | 11:32 AM
  #3386
daverx7's Avatar
IIRC, the width of the 245's were very close to the 255's and should shorten the gearing a tiny bit. I'm highly considering these tires, but would like to see them side by side to the 255's before I do.
James, if you happen to run across some 255 on 9" rims, would you mind taking a quick side by side shot to see how they look next to them?
Thanks,
-Dave
Old Feb 13, 2011 | 09:17 AM
  #3387
misterwaterfallin's Avatar
What are you guys running for front and rear ride heigth? Im getting everything put together and dont know where to set it at before I take it to get aligned and balanced
Old Feb 13, 2011 | 12:50 PM
  #3388
Random1's Avatar
From the ground to the fender edge (metal).
front = 24 1/4"
rear = 24 3/8"
With this and the rest of the setup the car is very neutral in low and high speed turns. You'll need really short shock bodies in the rear to go that low. You do not want to engage the bump stops during a turn.
Old Feb 13, 2011 | 06:53 PM
  #3389
front = 24 1/4"
rear = 24 3/8"
Thanks, Im on unshortened Koni's so I'll raise the rear figure a bit
Old Feb 13, 2011 | 07:27 PM
  #3390
762's Avatar
762
front = 24 1/4"
rear = 24 3/8"
Interesting that you run the front shorter then the rear, any reason for this? Or was that just how your corner balance turned out?
I have been running the rear shorter in hopes to help corner exit grip under throttle.
