S2000 STR prep resource
Originally Posted by TheNick,Nov 26 2009, 07:29 PM
Dave - I posted the Koni part numbers for the sleeves that will work with those earlier in this thread - I'm headed out the door right now - if you can find them lemme know
https://www.s2ki.com/forums/index.php?showt...post&p=16987010
For some reason I thought they were for a different Koni.
Thanks again!!
-Dave
Originally Posted by Aristoi,Nov 26 2009, 08:38 PM
Who am i going to run against next year? If both of you are out then i have nobody to strive to catch up to.
Originally Posted by daverx7,Nov 26 2009, 10:46 PM
Whoops!! Is this the post?
Thanks again!!
-Dave
Thanks again!!
-Dave
My NSX Wheels are exactly the same weight AP2 rear wheels - right around 21lbs. If you want to do STR on the cheap - thats the way to do it.
Originally Posted by TheNick,Nov 27 2009, 04:06 PM
Dave - yup thats it. Your DA's are the same body as a regular 80 Series Koni Yellow.
I thought these bodies looked bigger than my Yellows. I didn't realize the yellows had more than one size. Learn something every day.
Originally Posted by Random1,Nov 27 2009, 03:43 PM
What size/offset are NSX wheels? And those are "rear" wheels?
You can fold the lip flat in ST, you just can't re-shape the outside of the fender.
It really is odd, because originally the rule said you could roll the fender but not flare it. Rolling generally does mildly affect the outside shape of the fender within about 1" of the edge. But the latest "clarification" says that any change to the outside shape is not allowed.
