S2000 STR prep resource
Originally Posted by daverx7,Nov 27 2009, 03:19 PM
Good deal!! Thanks!
I thought these bodies looked bigger than my Yellows. I didn't realize the yellows had more than one size. Learn something every day.
You could call TC Kline too
Originally Posted by TheNick,Nov 28 2009, 08:20 AM
Yes. 17x8.5 +60
17x8.5 +65mm offset
Originally Posted by Random1,Nov 28 2009, 01:01 PM
...Just need to machine two for fitting the front hub which is 70mm vs rear at 64mm.
17x8.5 +65mm offset
17x8.5 +65mm offset
If you order 4 rear wheels from TireRack, you should be able to get them to give you give you a pair of front and a pair of rear hub rings. They did this for me when I ordered my SSR TypeF 17x8.5 wheels
Originally Posted by TheNick,Nov 28 2009, 07:21 AM
I could be wrong - if you get a chance - measure the circumference of the bodies with a string and I can compare to my Yellows.
edit
My TC Kline's are 82 series, the sports are 80 series
Thanks - good to know.
The part numbers are:
30.0000.0005 - threaded sleeve
30.0000.0006 - perch with locking set screw
They'll only work with 2.5" springs. The upper spring perch (if you wanted to use it) would be 80.0000.0007
