S2000 STR prep resource
Old Feb 12, 2010 | 06:39 AM
  #1211
alvanderp's Avatar
Originally Posted by Random1,Feb 11 2010, 06:58 PM
I had the unmodified one in the left rear, but you have to blindly do sweeps (turn, lift, turn) to adjust because it hits the rubber cover for the filler tubes. I did not like that. With the driver handle you can see how you are adjusting. I leave the hex part in the shock and just remove the handle. You can get them in and out if you pull the filler tube towards the trunk.
Mine must be the perfect length then. It engages the adjuster and bends right over the top of the adapter, so I can get it to pass under the boot for the filler neck. I don't lift and turn it, I can get it to do a 360 sweep. It's a bit cumbersome because of all the crap crammed in there, but doable.
Old Feb 12, 2010 | 06:49 AM
  #1212
TheNick's Avatar
The front Penske bodies are really short. I can't use a 6" spring and have adequate ride height. With the adjuster all the way up - the fender to hub height is 12". Leaves me no room for when its on the scales, nor does it leave room for 255's
Making some spacers today out of red glass to get another inch or two of ride height and still have adjustment with a 6" spring.
Old Feb 12, 2010 | 06:52 AM
  #1213
glagola1's Avatar
Dang! You need some 8" springs.
Old Feb 12, 2010 | 07:19 AM
  #1214
TheNick's Avatar
8" springs are heavy in high spring rates They have to use really thick coils.
It will be lighter to do it with the spacers, plus 6" springs are more common in the 800lb region.
Old Feb 12, 2010 | 08:13 AM
  #1215
glagola1's Avatar
I see....
Old Feb 12, 2010 | 11:20 AM
  #1216
alvanderp's Avatar
I used 7" springs, Hypercoil makes 7" 2.25's in pretty high rates(I had 900lb in the front). I was pretty close to the top of the shock body though, and that included using a helper isolator.
Old Feb 12, 2010 | 11:30 AM
  #1217
TheNick's Avatar
I made my spacers just for 2.5" springs for now. I've got enough things going on.
I've got some 6" 900lb 2.25" Hypercoils that I may try in the future. I'll make another set of spacers for those if necessary.
Old Feb 12, 2010 | 12:17 PM
  #1218
Rodney's Avatar
Originally Posted by glagola1,Feb 11 2010, 01:05 PM
And I've got some OZ Alleggeritas in 17x8.5 with a 59et as well. 1100 shipped.
pm
i have a set for sale too.... with dunlops. 300 miles ont he set. anyone want something lighter then the 949?
Old Feb 12, 2010 | 01:21 PM
  #1219
robinson's Avatar
How short?
Old Feb 12, 2010 | 01:47 PM
  #1220
TheNick's Avatar
14-15" or something like that? Measured from lower fork hole to end of body.
