S2000 STR prep resource
Originally Posted by NJDrive,Dec 19 2009, 07:27 AM
It sucks that anyone in an STR-prepped S2000 will have to fork over a mandatory $695(plus applicable tuning fees if needed) to be competitive. But I guess you have to pay to play like anything else. I do feel that having an AP2 is going to be a huge advantage.
As for staying on the rev limiter, The motor does shake around quite a bit. This cant be good for it among other parts of the drivetrain. Still, many guys racing their S2ks have bounced on it for many years/seasons. I feel if you keep it within reason and listen to the Hondata and other guys in the know, it should be fin for auto-x use. I will let someone else be the guinea pig though
The AP2 can handle 8600rpm just fine for quite some time, you just have to remember that engine wear is exponential and you are shortening the life of your engine. AP2 piston speeds are the same as AP1 piston speeds, so going beyond AP1 piston speeds would be too much of a risk IMO. Banging off the rev limiter is no exception, the good thing about auto-x is that it is in such short intervals. Road race guys are seeing about 20k miles worth of racing before the engine gets tired. AP1 valve train is built to handle 10k rpms, but 10,001rpm is likely to grenade the engine lol. Really, the bigger the engine the lower the rpm necessary because you make power sooner. The downside to a lower rev limit with a larger engine is the lower mph per gear, but racing is all acceleration and weight so to me there is no replacement for displacement. But it can all be seen as preference.
As for the Hondata reflash it is/was designed to slap onto a stock car, and a reflash is probably not a bad idea for someone that wants a tiny extra bit of power and the couple hundred rpm makes that big of a difference to them. The problem with the reflash stuff is that even though the tune was based off lots of experience each car is unique and requires a completely different tuning style. Then when you add exhaust and whatever else a reflash is really just cash thrown in the garbage. A good example of this is a customer of mines '07 Civic Si, it has I/H/E, and a mugen headgasket. He bought the Hondata flash pro and none of the tunes make the car run good in the entire rpm range. The car sounds like a diesel idling with the A/C on. My advice is invest in a custom tune unless you have a stock car like I mentioned earlier. Just my .02
Erik, I would like to hear more of your input on the aftermarket diff. According to Aaron, this may be a must have based on his before and after times on course...
Yes, I think a good clutch-type LSD will prove to be a significant improvement for those serious about STR. Simply stated, you will be able to pick up the throttle sooner and more aggressively than what is possible with the factory torsen.
Originally Posted by BrianGT,Dec 22 2009, 12:30 PM
Prices on the OS Giken LSD are going up after Jan 1st. I ordered one this week for my wife's Xmas present.
I think they are going up 10% IIRC
