check engine light=slower car?
Old Jun 11, 2006 | 12:14 AM
  #31
white-stingray's Avatar
it was actually reset using a scanner it turned off for about 30 seconds then came on again with the same code even tho the problem was fixed
Old Jun 11, 2006 | 12:39 AM
  #32
SenderGreen's Avatar
There it is again
If you cleared/erased the DTC with a scanner and the ECU immediately (30 sec) issued another instance of the same DTC, I would double check all the work. Perhaps the new O2 sensor was damaged during installation.
EDIT:I suppose the O2 sensor wire could be damaged somewhere else in the car.
EDIT:I was looking in the Helms, and it say's the resistance on the O2 sensor side of the harness should have been measured and continuity checked before the O2 sensor was replaced. If those two things have not been done it may be a good place to start. Next they say to check for battery voltage at the O2 sensor side of the harness. If thats good then they say check continuity at the ECU end of the harness. Finally if it is not a short or damaged wire they say to susbstitute a known good ECU for testing. Good luck.
Old Jun 11, 2006 | 06:45 AM
  #33
xviper's Avatar
Then the problem was not fixed. Getting this code involves a whole series of checks and measurements and procedures. Changing the sensor is but only one of those items but not necessarily THE solution.
trymev8
Feb 4, 2012 10:15 PM
J-me
Aug 5, 2005 10:11 AM
Chr-2004
Jul 20, 2005 05:49 PM
demonderrick
Jul 12, 2003 05:16 PM
KDuke
Jan 19, 2002 07:25 AM
