Power sticking in 1st
Old 11-08-2007, 03:37 AM
blakpawn's Avatar
Default Power sticking in 1st
Hi,
Over the last week I have noticed odd occasions, usually during rush hour when I've been queuing for a large roundabout, I finally get on the roundabout, give it a good squeeze in 1st but round about maybe 4-5000 rpm, the car stops accelerating for a few seconds then it seems to clear itself and continues on.
It feels like it's choking or as though Im waiting for the turbo to kick in [yes I know theres no turbo on my S]{none technical diagnosis there}, although there is no particular noise.
I can't be sure if its on the point of vtec engagement or not since its an intermittent problem and Im usually looking at the road in rushhour traffic rather than the revometer.
Other times its completely fine.
And I don't think Ive noticed it in any other gears.
It seems more likely to happen if Im progressive with the accelerator, when I floor it it never happens [so far].
Anyone have any suggestions what might be causing it please ?
I'm not treating it as serious for the mo, its just a niggle I hope.
Many Thanks
Old 11-08-2007, 04:04 AM
Jel
Jel's Avatar
Crap petrol, dodgy map sensor, very low oil, dirty/faulty injectors, squirrels in your air box?.
I'd disconnect the battery and tap the map as a starter.
Old 11-08-2007, 04:29 AM
Shipley's Avatar
Sounds like your MAP sensor.
Unplug the lead...unscrew the 2 holding screws and take it off. Give it both a clean (by blowing into it) and a tap with a screwdriver handle (plastic or rubber).
If thats what it is, this will cure it.
Old 11-08-2007, 04:52 AM
MB
Member
MB's Avatar
See the link in my thread below.
Its generally heat soak or MAP related.
Old 11-08-2007, 06:12 AM
blakpawn's Avatar
Thanks, Ill check out the MAP sensor tonight.
I'm not an engine person but I can tap something with a hammer.
I always use 98 octane but it could still be dodgy I guess, and the oil was checked last week.
9ineballer
10-15-2014 12:55 AM
RedLineS2k10
11-21-2010 09:51 PM
DFWs2k
05-24-2010 02:20 PM
Planets
08-02-2005 10:44 PM
awinskill
10-14-2001 10:56 PM
Quick Reply: Power sticking in 1st
