BRP/SOT Hotside SC Install
Great numbers. Comparing this to Comptech's kit with aftercooler on an AP1 (on Comptech's website), the SOT kit is putting down 30whp/58 ft-lb more @ 3000 RPM, 40whp/58 ft-lb @ 4000 RPM, 63whp/67ft-lb more @ 5000 RPM, 51whp/47ft-lb @ 6000 RPM, 71whp/24ft-lb @ 7000 RPM, 51whp/33ft-lb more @ 8000 RPM, and finally, 45whp/23ft-lb more @ 8800 RPM. In other words, it destroys the centrifugal kit. This thing should simply walk away from a Comptech'd S2k with aftercooler at the standard boost levels. The AP2 should put down even more torque.
Originally Posted by MugenRioS2k,Apr 7 2007, 03:21 PM
I still think I may have some belt slip and need to try out a gatorback belt to see if that helps any. I also have one more pulley option that will put it right at 18k.
First I am going to play around with removing the IC and using the current pulley configuration to see what the actual loss is with the IC - thinking it is dropping somewhere in the hood of 1 to 1.5 PSI.
Originally Posted by neeman77,Apr 9 2007, 12:11 PM
I did a dyno overlay for you guys starting at 3000 rpm. I just grabbed a dyno graph off this site of an ap1 with a catback. Enjoy!
... could you do the torque overlay too?
Originally Posted by joes sled 2000,Apr 9 2007, 02:09 PM
What exactly are you using for engine management?Keep us posted on the progress!
I plan to go with either the AEM piggyback or the Hondata K-Pro once one of them comes available.
As far as the question about when it will be available - it ties into the engine management issue. The ELF is not a perfect solution - SOT is looking at other options (an improved ELF version, AEM PB, etc..). They will also offer the kit as a tuner kit where you can select your own management option (EMS, eManage, etc.). Along with providing a turn key kit with engine management - the last mechanical phase for SOT is to finalize the IC kit in order to offer it as a tuner kit. This should be done by the end of April.
