Greddy Turbo Questions thread....
Old Mar 13, 2008 | 09:05 AM
  #121
kix's Avatar
kix
Yea, pick up a OBDII scanner. Since the install I've had about 3-4 check engine lights. All false alarms thankfully.
Old Mar 13, 2008 | 09:30 AM
  #122
S2005x's Avatar
ok, so ill go do that on my lunch break at advanced auto parts. ill post the code in a few hours.
Old Mar 13, 2008 | 10:10 AM
  #123
Spec_Ops2087's Avatar
Originally Posted by NFRs2000NYC,Mar 13 2008, 12:14 AM
My friend with a turbo RSX has a test pipe, and it doesn't smell at all. Nothing over stock. Is the s2000 that bad?!
You'll also find some people here complain about the STOCK exhaust drone and how unbearable it is
Its a matter of personal opinion. As far as I'm concerned, with a single 3" exhaust, no cat, just straight from my rich running turbo I hardly smell anything. It was the same when I was NA. Some people just like to complain a lot
Old Mar 13, 2008 | 10:13 AM
  #124
Originally Posted by NFRs2000NYC,Mar 13 2008, 02:27 AM
Hey guys....if I want to buy this gauge...
http://www.autometer.com/cat_gaugedetail.a...gid=3546&sid=60
What do I need to install it? Does it come with a sender unit? Where can I attach it to?
Also, what's the normal oil pressure range for the s2000 (psi) and what's the "oh damn, i gotta worry level"?
No idea about what it comes with but you'll need a pressure sending unit if it doesnt come with one. You can get the greddy oil filter sandwich block that lets you install 2 sending units (oil temp / oil pressure) or you'll have to T the oil warning light.
Start up is around 80psi. Once warm, normal driving is ~60ish psi, warm idle is usually 20ish psi.
The "oh shit" level is when your driving and its at 0 psi . Hopefully you can't catch the pressure droping before you hit that point however
Old Mar 13, 2008 | 10:14 AM
  #125
Originally Posted by honda_s2k_racing,Mar 13 2008, 11:38 AM
Guys, i have a problem!
I think its the check engine light... its yellow... looks like a motor... just poped on yesterday!
Tune day isnt until the 22nd!
I'm scared!
I bet its a misfire code / running rich code due to it being untuned...
Old Mar 13, 2008 | 10:29 AM
  #126
devs2k's Avatar
Originally Posted by TRBOKEV,Mar 13 2008, 12:50 PM
Read the code.
Welcome to the world of FI.
haha
actually, most people have the AEM so they can't even produce/read codes
Old Mar 13, 2008 | 10:47 AM
  #127
Nyther's Avatar
When tuned on a dyno, the cel codes should go away and only come up with the basemap due to the "rich" tune?
and, whats better for the greddy kit, the Greddy Profec spec II boost controller or the AEM Tru-Boost.. they are both about the same price but i dont know which one would be the best...
Old Mar 13, 2008 | 11:06 AM
  #128
NFRs2000NYC's Avatar
Doesn't the Greddy oil relocation adapter have a fitting that you can mount an oil pressure gauge to?
Old Mar 13, 2008 | 11:58 AM
  #129
Chris_Lum's Avatar
Correct, if you buy the greddy turbo kit, you have a total of 5 spots for sensors on the two adapters (block side and oil fiter side). I did a print screen from the manual, here you go:
Old Mar 13, 2008 | 11:59 AM
  #130
What's in the other ports if they are not used? Is there a plug in them or something?
