Official forced induction chat thread
Old Mar 2, 2014 | 07:34 PM
  #471
neeman77's Avatar
S2-Kai, there were likely some small shavings in the transmission from a few grinding gears etc and the fluid wasn't changed often. It isn't going to affect the strength of the gear, don't worry about it.
Old Mar 2, 2014 | 08:29 PM
  #472
S2-Kai's Avatar
I'm hoping it's nothing too. Thanks Neema, I got the Z differential running in my car, and it uses the stock axles!! Hopefully, I'll get the trans in this month. Between spring break and moving, I just hope I'll have enough time to put in work
Old Mar 3, 2014 | 11:43 AM
  #473
s2klariat's Avatar
What size socket is needed to remove the factory oil cooler? Or do you not need to remove the "threaded" part where the oil filter screws on to get it off?
Old Mar 3, 2014 | 11:53 AM
  #474
Redline S2K's Avatar
Oil cooler housing bolt head is 30mm. It is a long bolt and one piece. If you remove it and don't run the oil cooler, you need a replace it with something shorter. I think the filter thread adapter from a civic will work. Can't remember what year though.
Old Mar 3, 2014 | 12:05 PM
  #475
herecomesboost's Avatar
Old Mar 3, 2014 | 12:09 PM
  #476
Originally Posted by herecomesboost
Good pic, part number and all for you.
I remember someone was looking for a knock sensor. Looks like Ballade offers a replacement one.
http://www.balladesports.com/product...-30530-pcx-003
Old Mar 3, 2014 | 12:53 PM
  #477
Sylvain2000's Avatar
I know that there is a Lot of hate concerning the greddy e-manage ultimate but is there anyone here who uses it ???
Old Mar 3, 2014 | 01:02 PM
  #478
I don't know if hate is the correct word. E-Manage just doesn't compare to a full standalone (AEM/Haltech).
Old Mar 3, 2014 | 01:40 PM
  #479
^^^ yes I know.
That is the main reason I went with it. I like to keep the oem ecu in the loop.
Old Mar 3, 2014 | 02:32 PM
  #480
sohc_mshue's Avatar
Why would you want the oem ecu in the loop?
