Official forced induction chat thread
Old Dec 17, 2013 | 10:25 AM
  #141
d-bo's Avatar
Originally Posted by jordannn93
What is the most psi I can get tuned on with pump 93 safely? 9.6:1 compression built bottom motor.
Depends on your turbo lol. Do you have a 50trim or a 42r
Sent from my iPhone using Tapatalk
Old Dec 17, 2013 | 10:26 AM
  #142
jordannn93's Avatar
A 50 trim lol BW363 1.10ar
Old Dec 17, 2013 | 11:26 AM
  #143
d-bo's Avatar
My friends 6262 with an 8.8:1 comp motor is on 22psi on 93 but his tuner is not good. So who knows. His car only makes 540hp
Old Dec 17, 2013 | 11:27 AM
  #144
d-bo's Avatar
Anyone have any tips and tricks to removing the crank pulley bolt
I'm sure some of you have had your motors apart more often than together
Old Dec 17, 2013 | 11:28 AM
  #145
APoner's Avatar
Originally Posted by CoolGuy094
I have a fueling problem...
On the dyno we discovered that the o-ring behind my FPR was in pieces. We replaced the o-ring but we aren't getting enough fuel delivery at upper RPM's. Fuel setup is ID1000's, stock rail, stock FPR, stock lines, Aeromotive 340 pump wired in with a relay. Only shooting for 350-400 HP on a Novi 1220 setup.
We have no clue how long that o-ring had been like that, and it could have been obstructing flow or not allowing fuel pressures to be consistent/correct. Ben thinks the pump is just not capable of flowing what its suppose to at the top-end, i.e. the pump has gone bad from this issue.
I'm planning on removing the injectors and sending them back to ID to have them cleaned/flow tested (~$80), swapping in a new pump (~$150), and a new FPR from Honda just because (~$90) and making sure my fuel rail is clean/clear. Anything else I should look into?
Im curious to see what you put down once everything with the fuel is figured out. What pulley are you going with? Do you have you setup posted anywhere?
Old Dec 17, 2013 | 12:25 PM
  #146
CoolGuy094's Avatar
Why not just buy an aftermarket fpr and rail ?
I have an in cabin gauge on mine so I can make sure I am getting enough fuel supply without playing any guessing games. At least you will know the pump is probably the problem
Thanks for your advice; I'd like to stick with the OEM FPR and fuel rail (since most other medium-level SC builds do the same), but I'm quickly realizing that a fuel pressure gauge would be extremely helpful here for troubleshooting purposes.
Anyone have any tips and tricks to removing the crank pulley bolt I'm sure some of you have had your motors apart more often than together Sent from my iPhone using Tapatalk
Best I can suggest is using the crank pulley tool, allow the tool to rest against the cross member and use a big beefy 3/4" drive breaker bar with a steel pipe extension over it. And put lots of towels down to protect your fender from the breaker bar once the bolt breaks loose, lol. I've gotten two off this way, and one was on a MY00 with 125k miles.
I have the 3.4" pulley which SOS has listed as 11.25 PSI on their chart (AP1). I saw 13 PSI max during my previous trip to the dyno. I don't have a build thread or anything, but I can tell you whatever you want to know in a PM or something if you're looking for info. I should hopefully hit 350 HP on this dyno (SuperFlow) which might be equivalent to about 380 HP on a DynoJet.
Old Dec 17, 2013 | 01:04 PM
  #147
d-bo's Avatar
Luckily my timing chain jammed up the rotating assembly so it came loose with barely any effort lol.
What do you guys think of my piston ?
Old Dec 17, 2013 | 03:57 PM
  #148
herecomesboost's Avatar
Using the Honda pulley tool, I pull with one breaker bar and push with the other. Broke loose immediately (116k miles); engine out of the car/on an engine stand. Otherwise, I would have done what CoolGuy094 recommended.
Geez, that piston looks terrible Eric. How scored were the walls of your block?
Old Dec 17, 2013 | 04:27 PM
  #149
d-bo's Avatar
It ripped off super quick I am glad it wasn't in the car. I'm sure I would have hit my hand, or bar into the fender lol.
Cylinder 4 had a penny-nickel sized chunk missed along with pretty deep scores. There was scoring in each cylinder with decreasing severeness from 4-1 both vertical and horizontal. Piston 4 was toast , piston 3 showed some wear and 2&1 seemed Ok. I think this would be from cylinder 4 running the hottest naturally ? Not sure. I'm not an engine builder or anything but the bearings seemed like they were fine and the crank was fine as well with no scoring. There was still oil in the squirters so I think they were working properly. Didn't seem to be an oil starvation problem
Old Dec 17, 2013 | 05:04 PM
  #150
redboost10's Avatar
ive never had a problem using a 1/2" drive air gun
