Official forced induction chat thread
I have a fueling problem...
On the dyno we discovered that the o-ring behind my FPR was in pieces. We replaced the o-ring but we aren't getting enough fuel delivery at upper RPM's. Fuel setup is ID1000's, stock rail, stock FPR, stock lines, Aeromotive 340 pump wired in with a relay. Only shooting for 350-400 HP on a Novi 1220 setup.
We have no clue how long that o-ring had been like that, and it could have been obstructing flow or not allowing fuel pressures to be consistent/correct. Ben thinks the pump is just not capable of flowing what its suppose to at the top-end, i.e. the pump has gone bad from this issue.
I'm planning on removing the injectors and sending them back to ID to have them cleaned/flow tested (~$80), swapping in a new pump (~$150), and a new FPR from Honda just because (~$90) and making sure my fuel rail is clean/clear. Anything else I should look into?
The o-ring was kinda shredded, but it looked as if the vast majority of it was accounted for. Any remaining pieces wouldn't be large enough to block a line, but tiny pieces could possibly be in the injectors or maybe in the banjo fitting on the return pulsation damper, which is why I'm thinking of having the injectors cleaned/flow tested and cleaning the rail, etc.
Why not just buy an aftermarket fpr and rail ?
I have an in cabin gauge on mine so I can make sure I am getting enough fuel supply without playing any guessing games. At least you will know the pump is probably the problem
Sent from my iPhone using Tapatalk
