Official forced induction chat thread
Old Feb 28, 2014 | 10:59 AM
  #461
spectacle's Avatar
I was just watching 2F2F and I can't believe how bland and shitty the pink S2k sounded. Wasn't that thing SC'd? Is that how all SC'd cars sound?
Old Feb 28, 2014 | 01:54 PM
  #462
CoolGuy094's Avatar
Lol. Someone just told me today how surprised he was at how quiet my blower is. I think its kinda loud personally. But I have an OEM exhaust, so relatively speaking mines quiet as fawk.
Old Feb 28, 2014 | 02:58 PM
  #463
Mr.60trim's Avatar
NEVER use anything from the F&F series as a meaningful reference
Old Feb 28, 2014 | 06:27 PM
  #464
Mr.60trim's Avatar
Just throwing out an idea here...
Those of us who use an AEM ems, any thoughts on whether or not the AEM FIC piggyback could theoretically be used as a (quick fix) for the OBDII port emissions?
It controls timing, fuel delivery, has it's own on-board MAP sensor, and works in conjunction w/ the stock ems. My thoughts are, when that time of the year arrives utilize the FIC, hook up both O2 sensors back onto the exhaust, and disconnect a charge pipe (for safe measure). Assuming you can calibrate the FIC to mimic factory settings without having to remove the larger injectors, colder plugs, and aftermarket MAP sensor you should pass? or am I missing something here?
AEM FIC
Old Mar 1, 2014 | 06:41 AM
  #465
MBHs2k's Avatar
Guys I should have mentioned that I already have the upgraded water pump from the CTSC. That should be upgraded was well?
Old Mar 1, 2014 | 07:39 AM
  #466
Redline S2K's Avatar
I think it was Sport Compact Car magazine (that still around?) that had an article about all the 2F2F cars and the s2k was the only one that actually performed like it was shown in the movies. The others were all stock.
Old Mar 1, 2014 | 10:18 AM
  #467
illestrolla's Avatar
S/C cars sound just like N/A cars. At least in terms of sounding like poop and having rasp issues. Nothing at all like a turbo car.
Old Mar 1, 2014 | 11:26 AM
  #468
DaGou's Avatar
My SOS SC sound like a cement mixer full of bolts. I also have have CF hood with no sound deadening.
"I used distilled water and a bit of water wetter, which you can find in any car parts place. "
I used Purple Water Wetter. On the bottle it said not to use distilled water... so be careful to follow the instructions on the brand you buy. Also, obvious but, if you live were temps drop below freezing water wetter is not anti-freeze. It will freeze and burst your HX and aftercooler.
Old Mar 1, 2014 | 03:44 PM
  #469
S2-Kai's Avatar
Originally Posted by S2-Kai
Hey everyone, I posted this in the Under hood forum but thought I'd try my luck here as well... This is a 350z trans that I will be swapping into my S. The bottom gear has some surface scarring that I can't figure out. Any ideas? Should I be worried? No other damage on any of the surrounding parts, or excess shavings or metal chunks...
Nobody has any ideas what those marks are???
Old Mar 2, 2014 | 03:22 PM
  #470
AFK-S2K's Avatar
Originally Posted by AFK-S2K
Anyone know if the factory heat shielding (the cloth like material) that is on the underside of the hood can take the heat of a full-race pro street manifold?
The mani is 1600 degree coated and i plan on making the typical fuse box heat shield for it, but i dont want to burn the hood heat shielding (or paint for that matter).
Still looking for an answer on this. Will the oem heat shielding on the underside of the hood hold up to the temps? I usually see pics with it removed, but I would like to keep mine if it's useful.
