The Ultimate GReddy Turbo Kit Thread
any of you fellas that have the kit running on there care for a while experience a TPS check engine light?
it comes and goes? sometimes i turn the car on in the morings and its there then the next day it goes away? happens often
ok.... now i got some money saved up and I'm in the market for a used t518z 10cm. is there anyone selling???
and also is there any turbo rebuild shops in socal that you can recommend? thanks guys
Does anyone happen to know if the revhard manifold bolts up with the Greddy turbo? I was looking to upgrade to an external wastegate and eliminate the internal greddy one. The manifold look the same, but I wanted to see if anyone else has done this to eliminate the wastegate issues instead of porting the internal one. Thanks.
How is everyone doing the turbo drain setup on these GReddy kits? I just don't see how the drain from the kit can work I mean the drain plug is the lowest point on the engine so wouldn't it need to be above that? Anyone having oil draining issues?
