The Ultimate GReddy Turbo Kit Thread
Old Jul 27, 2011 | 05:19 PM
  #1201
S2k.berto's Avatar
Originally Posted by guamie
what's really sad here is how many people NEED the replacement manifold from Pang. greddy manifold
Lol greddy needs to jump on this asap. There's defently a demand
Old Jul 28, 2011 | 10:04 AM
  #1202
itlynstalyn's Avatar
Greddy originally was supposed to make an upgrade kit, don't know the specifics but I'm assuming it was scrapped.
It's not that people NEED a replacement manifold from pang, it's that they want an ELM that breathes better.
Old Jul 28, 2011 | 10:31 AM
  #1203
guamie's Avatar
there's also alot of people with cracked greddy manifolds. thats what i was referring to.
Old Jul 28, 2011 | 11:22 AM
  #1204
Nyther's Avatar
I'm wondering ( besides a more reliable header ) what actual gains could be made..
I'm assuming the greddy turbo would not go any further than 340 whp or something like that, but should people get higher mid range/peak numbers compared to the LOG manifold?
I'm about to order a PFAB log mani but if PFAB is going to produce something better, then i'll wait..
Old Jul 28, 2011 | 03:19 PM
  #1205
The Pfab log isn't going to make much more power than the greddy.
An ELM will definitely allow the turbo to breath better if you've upgraded it as the T518Z is going to run out of breath pretty quickly. I've squeezed all the horsepower I can out of the log.
Old Jul 28, 2011 | 04:34 PM
  #1206
Nyther's Avatar
So an ELM will be pretty useless unless you upgrade the turbo? Im curious what a powerband will look like if you would compare an ELM between the cast mani..
Old Jul 28, 2011 | 05:03 PM
  #1207
guamie's Avatar
anyone with the replacment manifold know how much they gained with it? i asked pang about it, and he said roughly about 10whp depending on the tune.
Old Jul 29, 2011 | 09:01 AM
  #1208
Originally Posted by itlynstalyn' timestamp='1311895161' post='20826002
[quote name='Nyther' timestamp='1311880944' post='20825226']
[/quote]
It won't be useless, it will definitely make more power at a lower PSI. ELM's are much more efficient, I just don't know what the top end people are running the T518Z at right now. I'd say 14-16psi is probably the max.
Old Jul 29, 2011 | 09:43 AM
  #1209
Kitesurfer s2000's Avatar
10psi is 10psi on any mani the difference will be with a elm is that you will be running colder so you can increase your psi .If you change the mani and get 2.5 ic piping then 18 to 22psi should be possible the evo boys are running that turbo upto 25psi.
Old Jul 29, 2011 | 11:32 AM
  #1210
It's not about increasing your PSI to get more power, it's about the efficiency of the manifolds runners and collectors allowing the exhaust gasses to flow more freely. The main part of an ELM is increasing volumetric efficiency.
