The Ultimate GReddy Turbo Kit Thread
Old Oct 9, 2009 | 09:24 AM
  #701
Chris_Lum's Avatar
Originally Posted by devs2k,Oct 9 2009, 10:19 AM
Get the Greddy 70mm with stock or HFC. I prefer Greddy 70mm with stock cat because that's the cheapest option. This is 100% guaranteed to limit boost creep.
The lighter weight of the J's won't matter now that you will have 280-300whp
Also, once you are tuned, and for some reason your stock cat takes a crap due to age or what not, you can grab a used one for $50-100.
Which J's are you talking about? I had a J's 70 rr, but that's a full headerback which you do not want.
Old Oct 9, 2009 | 11:43 AM
  #702
lude9285's Avatar
[QUOTE=devs2k,Oct 9 2009, 09:19 AM] Get the Greddy 70mm with stock or HFC.
Old Oct 9, 2009 | 11:47 AM
  #703
devs2k's Avatar
Originally Posted by lude9285,Oct 9 2009, 03:43 PM
What's the Approx. Hp difference using the stock cat vs HFC? 15-20hp?...Less/more?
Normally it would be a hands down decision for me (greddy tic w/stock cat) because, as you said, its a lot cheaper. But the used kit im looking into can/will come with a HFC. Its just a question in rather i want to use it and if the increased flow is worth worrying about boost creep.
The J's exhaust i was thinking about is the fx 70rs. It would also be a used item so the price would be extremely drastic...
unless i'm also able to find a used greddy tic single in Socal.
If it comes with the HFC then you may as well use, I don't know how much it's worth anymore
Power difference can't be more than 10-20 whp. I honestly can't tell you that you will not experience boost creep with the HFC; hopefully someone can answer that for you. I knew a guy running a HFC + 70mm single or dual but ran 12 psi (JOEY LOL)
Aren't new Greddys <$700? How much is this J's you are looking at.
Old Oct 9, 2009 | 11:52 AM
  #704
Chris_Lum's Avatar
Gotuning is selling the TiC 70mm single for something like 585.00 cash otd.
https://www.s2ki.com/forums/index.php?showtopic=733146
Old Oct 9, 2009 | 11:54 AM
  #705
lude9285's Avatar
[QUOTE=devs2k,Oct 9 2009, 11:47 AM]
  #706
devs2k's Avatar
You may as well get a Greddy license plate frame to complement your turbo and exhaust LOL
Old Oct 10, 2009 | 04:27 PM
  #707
sammy21c's Avatar
Originally Posted by jari8378,Oct 6 2009, 02:36 PM
Hey sammy,
my tuner said that my exhaust is really restrictive and is causing detonation problems... Did your tuner say anything?
No, he only said about this kit was it is way too rich. Now I am having pretty bad boost creep.
Anyway, what kind of spark plug are you using? Be careful with non resistance type thing.
Old Oct 10, 2009 | 08:33 PM
  #708
JoeyBalls's Avatar
Sammy, I had bad creep as well, get a HFC it willgive the greatest amount of flow without creep.
Get heat range 8 plugs.........
Old Oct 11, 2009 | 10:01 AM
  #709
SOHCmyDOHC's Avatar
Originally Posted by lude9285,Oct 10 2009, 05:00 PM
I just did a compression test on my car today ($25 DIY'er)
My cars an AP1 with 102k on it.
What are your guys thoughts on these #'s...
cyl. 1- 183
cyl. 2- 180
cyl. 3- 176
cyl. 4- 181
Safe to boost?
What's new around 230psi per cylinder? Our cars come 190-200whp stock right? Is the correlation direct, since i have lower compression #'s my hp is prob on the lower side?
Your motor is tired bro.
Old Oct 11, 2009 | 11:17 AM
  #710
Revenge's Avatar
Just think of it as a lower compression motor. Why do your think there is a problem? Your dyno numbers seem real good?
