The Ultimate GReddy Turbo Kit Thread
Originally Posted by Ahnold' timestamp='1316895229' post='21002516
[quote name='S2KCHRIS305' timestamp='1316875428' post='21001905']
Hey guys I got a problem . I got the Greddy kit . But no tuner in my area wants to tune it for me. They say its a terrible kit .
[/quote]
Ebay, can't remember the name of the shop. Turned out that is was in my area too. Some shop in Hillsboro, OR. This was 3 years ago though.
I tried searching around this thread, and I noticed the original post says that the boost controller not essential but nice to have. I'm a turbo noob, and I just finished piecing together a greddy turbo kit. I pretty have everything ready to install, but after reading this thread I noticed I do not have a boost controller. Do I need one to have my car tuned? I will be running the EMU if that helps.
EDIT: Just looked at the dyno results in the original post. Does stock boost make it up to 300hp @ 10psi? Or will I only be able to achieve that with a boost controller?
I use the AEM Tru boost myself on stock kit. Works great with boost spike. In summer I turn the kit up and in winter turn it down to prevent the spike. I love the kit and any body that says its not a good kit just doesnt wanna tune the EMU and wants to sell you there kit. I had a 5 hour cruise with friends a few weekends ago and did alot of hard playing and had no issue with the kit whatsoever. Like others said get you a good A/F gauge and learn to fiddle a little with it yourself. I learned to play with it a little myself and it actually is so easy to tune with. Read on this
http://www.fitfreak.net/forums/fit-f...-ultimate.html
After reading all the pages I have a couple questions. Just picked up a used kit. I have a stock 2000 Ap1 with about 100kmiles. Plan just to be a nice street car with about 280-300hp with HFC and stock exhaust. No real track time but might go to a track day one time out of the year.
1.Do you need or have to upgrade the oil jets/banjo bolt?
2.Is the oil return line ok or do we NEED to tap/weld bung? -10 fitting? Or Ok for track day as is?
3.Was reading that we don't need to use the air pressure relocator/bypass if we have a blowoff valve? Do we just leave it as is then?
4.Anyone use nord lock or stage 8 bolts or both. What about the turbo downpipe and manifold studs. Do they have to be ARP? Friend said just to get some nissan ones.
5.Someone asked about wrapping the downpipe with heat wrap. Anyone done that or a turbo wrap cover? IT worth it?
6.HFC. Which one to get? 60 or 70 mm? Stock exhaust for now but maybe going to change that in the future.
Thanks in advance.
Thanks in advance.
Originally Posted by S2k.berto' timestamp='1317266169' post='21020464
[quote name='RedSunS2K' timestamp='1317262127' post='21019914']
[/quote]
you will want a boost controller to get to 10psi.
