The Ultimate GReddy Turbo Kit Thread
Old Aug 6, 2009 | 08:29 PM
  #561
2006ap2's Avatar
question, greddy claims the kit is safe to drie out of the box, others say get a tune, some say dont even drive it to the tuners, trailer it. if you use the base map it should be good to drive right?
Old Aug 7, 2009 | 07:16 AM
  #562
JoeyBalls's Avatar
yes
Old Aug 7, 2009 | 07:23 AM
  #563
Revenge's Avatar
You can drive it to the tuner, it may not run great but it should be more than fine. Now if you run a TP and large exhaust be super careful. But the base map was tuned with a 80mm single and a stock cat. Anything other than the stock cat you should not boost with out a tune. Also the tune will let your run better and you can turn up the boost to make more power with a boost controller.
So get a good boost controller
A Berk 63 HFC which may or may not be needed if you use a 70mm single
And an 60-70mm exhaust nothing bigger
Old Aug 7, 2009 | 01:34 PM
  #564
2006ap2's Avatar
Yeah, I have a stock cat(danm smog laws) and an invidia n1 exhaust.
Old Aug 7, 2009 | 01:40 PM
  #565
devs2k's Avatar
have you bought a kit?
Old Aug 7, 2009 | 03:09 PM
  #566
2006ap2's Avatar
i bought the greddy kit, havent got it yet though, its on backorder. i should get it within the next month.
Old Aug 7, 2009 | 03:36 PM
  #567
devs2k's Avatar
Just wondering since I have a DBW kit for sale, albeit used.
Have fun with it
Old Aug 13, 2009 | 02:44 PM
  #568
asukadc's Avatar
i want to put a turbo blanket on the turbo... do i need to remove the turbo for this? or this will just go on from underneath without removing stuff? like this one... http://cgi.ebay.com/ebaymotors/Turbo-beeni...sQ5fAccessories
Old Aug 13, 2009 | 05:39 PM
  #569
edomund's Avatar
When I put mine on I had to cut it to fit our turbo because of the external WG. That one is probably the same which means you have to take the turbo off to custom fit it. it pretty easy just use a pair of sharp shears. I used some mechanics wire to hold it on the turbo since I had to cut the eyelits off.
Old Aug 18, 2009 | 05:54 PM
  #570
Josh_With_The_S2K's Avatar
what are some ways of removing or helping the "vtec dip" we get?
