The Ultimate GReddy Turbo Kit Thread
Old Dec 3, 2009 | 06:32 AM
  #741
asukadc's Avatar
Originally Posted by Crackerballer,Dec 2 2009, 08:09 AM
asukadc, I was reading more and it seems a nice oil cooler is the trick. When I say trackable, I really mean time attack. I think EMS and all the right senors is key as well.
^^^ same here, that's why i mentioned winter vs summer/ sessions vs lap. time attack.
assuming there is a HUGE difference winter vs summer tracking right?
Old Dec 4, 2009 | 03:12 PM
  #742
razzele's Avatar
Hiya guys
Im in the process of amassing all the parts I require for my conversion.
Id like a bit of advice with regards to gauges.
What should i be measuring ? Im thinking Boost /AFR, oil temp and pressure.
I really dont want more than 2/3 gauges in the car though ?
What have you got? what would you recommend? What works well with this kit?
Im also needing an oil cooler- any recommendations resulting from trial and error?
Thanks
R
Old Dec 4, 2009 | 09:15 PM
  #743
UpsFella's Avatar
Originally Posted by razzele,Dec 4 2009, 04:12 PM
Hiya guys
Thanks
R
AEM wide band afr
AEM tru boost
Old Dec 5, 2009 | 12:52 AM
  #744
razzele's Avatar
No oil temp & pressure ??? Why not?
Old Dec 5, 2009 | 01:06 AM
  #745
chad86's Avatar
I would say only AFR and boost are necasary... the oil pressure would be next in line, then oil temp/water temp
Old Dec 5, 2009 | 03:50 AM
  #746
asukadc's Avatar
pressure not really needed, cuz on gauge cluster... factory is got one.. and by the time it fails... YOU WILL KNOW.
Old Dec 5, 2009 | 09:27 PM
  #747
CaseyGW's Avatar
on the relocator kit, are the fittings NPT threaded into the actual relocator pieces or are they AN threaded?
Old Dec 5, 2009 | 09:53 PM
  #748
Suzuka_Joe's Avatar
uh oh, is my kit coming off easily?
Old Dec 6, 2009 | 04:42 AM
  #749
SgtB's Avatar
I can't remember if the threads are NPT or a straight thread. The fittings have an O-ring under the mating face to seal them to the housing. The fitting to hose connection is an AN conical style seal. I do know that the center fitting on the engine side is female, so they are more than likely all special. Pull them and see.
Old Dec 6, 2009 | 09:03 AM
  #750
CaseyGW's Avatar
if they have o rings then they are staight an which is what i was hoping.
no issues with your kit joe, im buying a greddy relocation kit to replace the one im selling you, unfortunately the one im buying from my friend doesnt have real AN fittings so im upgrading it.
