Prepping for BSP
2.2 with stock manifold
2.2 with 50mm Hayward ITB
2.0 with 50mm Hayward ITB
2.0 with stock manifold
Right now, the 2.2 is in the car and the ITB's are on my shelf with a 'need to sell' sticker on them.
Mike, I can't believe they didn't mention you. Don't worry, I've been picked before and haven't won, so maybe it's better the other way around. Looking forward to running against you.
I don't have a problem not being mentioned. I haven't put two days together all year. Between bad driving and car breakage....maybe it will happen in lincoln for the first time this year
I'm glad to see 10 cars already registered for Lincoln...hopefully that number gets close to 20 before showtime.
.I'm glad to see 10 cars already registered for Lincoln...hopefully that number gets close to 20 before showtime.
My codriver(G Warren Hahn 2008 A stock National Champ) and I will be there in my 04 which should be about 90-95% prepped by Lincoln. We will be running BSP on the new Bridegstone R1S tire. I can tell those of you looking for power numbers that the initial STR tune on the car made 232hp and 166lb/ft. We are waiting on a few more parts but the car should be making a bit more power once we retune. We opted for 17x10 instead of the 18 route.Here is the original dyno chart
S2Ap2AemvsStkecu2.jpg?t=1311301235
Sacha
Sacha
Since I saw a number of you discussing 17x10s, I figured I'd post the other possible group buy for 17x10 +45s in the works right now.
https://www.s2ki.com/s2000/topic/965...8%85%e2%98%85/
http://www.sccaforums.com/forums/for.../posts/default
-Marc
We just mounted the 17x10 ulrs with 275/40/17 BFg all around we are running 52 frt and 73 rear. Ideally would have gone 73 all around and spaced the frt but they weren't available. From our str setup we went to 3.2 frt camber and raised the car about an 1/8 of an inch and had to severely roll/flare frt fenders. Rear only requires to roll the flat lip upwards
