S2000 STR prep resource
Old Jul 22, 2010 | 06:58 AM
  #2311
marks_lude's Avatar
Originally Posted by Random1,Jul 21 2010, 10:56 PM
When you say "stock valved" do you mean "off the shelf" or valved for stock class autocross (custom valving)?
Have you tried varying the rear rebound? I would try full soft if you have not already.
Be sure to go to full soft (stops) and then back off 1/8 of a turn. Koni sport rebound adjuster is not the best (described before). I would also try full soft on all corners.
Too much rebound in the front can inhibit weight transfer to the rear.
Sorry I should have said "Stock Class"
They have been re-valved for AS (BS), but are still single adjustable.
I realize I am limited with what I can do because they aren't DA's but I honestly don't know if I am setting them anywhere close to where they should be. I understand shock theory quite well, but driving a car and knowing how to feel what it is doing is very very new to me.
Old Jul 22, 2010 | 07:05 AM
  #2312
imstimpy's Avatar
Originally Posted by marks_lude,Jul 21 2010, 09:27 AM
Any of that make sense? I'd love to pull the rear bar, but with 225 front tires I expect a hindering amount of understeer if I do.
Is there any way to keep a balanced car, but keep the car either flatter or get more rear droop?
Go through the math of current bar wheel rates, remove the bar and then soften the front equally. That will leave your current balance and allow you to try increased rear droop.
Again, knowing your bar wheel rates allows you to soften up the bars and increase the springs. Doing so allows you to increase individual wheel movement without decreasing roll resistance. Keep in mind that most production cars need bars to control roll because the springs alone can't handle the job.
Old Jul 26, 2010 | 11:28 AM
  #2313
imstimpy's Avatar
Here are our results from this past weekend:
https://axwaresystems.com/axorm/file...7_2010_pax.htm
Pedroza drove Minehart's car in the afternoon.
Drew, Rob, and I compared mine and Drew's cars, swapping for a few runs in the afternoon. Though Drew's car had an extra 500rpm higher redline, his car was still bouncing the limiter at the exact same location as mine (indicating either higher corner exit speed or faster acceleration). Each car had its own driving style requirements, so the swapped cars were slower for the respective drivers.
We experimented with the Hankooks at 33psi and 35psi, 120*F to 160*F, and the times were all nearly identical. The times at 35psi were consistently faster than 33psi, but 35psi was all during afternoon runs. There may be a slight increase in rear bias approaching 160*F, but it is progressive so the driver can drive around the difference. Spraying can be done if the initial temp is hot enough and enough time is allowed for the tire to dry. If the run follows spraying too soon, the first braking zone is a little worse and rear slip is increased slightly. It disappears quickly.
Old Jul 26, 2010 | 11:38 AM
  #2314
TheNick's Avatar
Yup I have a feeling we are all going to be chasing 2nd place if Dan decides to drive Jason's car in Lincoln.
Old Jul 26, 2010 | 12:15 PM
  #2315
TheNick's Avatar
Got grip?
Old Jul 26, 2010 | 12:27 PM
  #2316
josh7owens's Avatar
you like the even tire pressure all the way around? I know some people have been running 38f/35-6r (rs-3)
Old Jul 26, 2010 | 12:38 PM
  #2317
mLeach's Avatar
Originally Posted by TheNick,Jul 26 2010, 03:15 PM
Got grip?
Pic one.... bicycling?
Old Jul 26, 2010 | 01:42 PM
  #2318
alvanderp's Avatar
Originally Posted by TheNick,Jul 26 2010, 12:15 PM
some pics &...
Got grip?
I saw Jon's car do this once at the event he referred to yesterday, granted he hit a bump while loaded up when it happened.
The only solace I can take from yesterday is after 3 runs, Dan was behind me in the STR car(thank you cones ), and those were his 8-10th runs of the day(he double entered and ran the CS MS-R first). That's my rationalization and I'm sticking to it!
The course was very difficult to get a 10/10ths run on, especially considering the bumpiness of the lot. But to be sure, he is going very fast in Jason's MX-5(smoked us at the divisional last weekend), and they still have some work left to do on it before Nats.
It was interesting to drive Jon(imstimpy)'s car after mine. Despite what most would consider small differences in setup, the cars did exhibit pretty noticeable differences in handling. Neither was necessarily better or worse than the other, just different. I obviously preferred the characteristics of my own car(which was a bit more point-y), but that is to be expected
Old Jul 26, 2010 | 04:41 PM
  #2319
imstimpy's Avatar
Tire pressures are easier to remember if they are all the same
While I was incredibly consistent this past event, I have yet to quantify differences in pressures while on course. I've now run 32-38psi and the only conclusion is higher pressures (~38psi) have a peaky feel to them.
Once I find a pressure I like, I tend to leave pressures alone except as a very fine tweak often coinciding with excessive heat.
I'm not saying any of this is right, but it is what I do...
Old Jul 26, 2010 | 07:25 PM
  #2320
robinson's Avatar
I just finished up my spherical bearing top mount project. I use TheNick's idea and it worked out great! So thanks to Nick for the R&D.
After a test drive I'd say the car is more composed over bumps and it has a more direct road feeling, which I like.
I also removed my Torrington bearings since they were mostly destroyed from rust and road grime. This gave me about a 1/4 inch drop which I badly needed.
