S2000 STR prep resource
Originally Posted by josh7owens,Oct 13 2010, 10:52 AM
How safe is this?
Would there be any gains to be had over the K&N filter?
Ps- RavynX I'm lovin that dark blue s2k! Might be my next color
Originally Posted by chetly,Oct 13 2010, 11:39 AM
Just in case anyone was interested, i measured the spring rate of the saner bar last night.
softest setting: 554lbs
medium setting: 667lbs
hard setting: 798lbs
I installed a set of J's Racing S2 camber joints this evening. Here's the camber curve before and after the install -
The dashed line is about where the stock ride height sits, ~14.2" hub center-to-fender lip. The fender lip clearance is improved by installing these joints.
Interestingly, I lost some droop travel by installing them. All of these measurements were taken without the coilovers installed, so the extreme ranges of travel may not be normally possible.
How did you measure? Any photos of the setup? I am planning to make a sway bar rate measuring tool using my spring rate tool.
Any chance you can do the rear with the same method?
Originally Posted by Random1,Oct 13 2010, 08:34 PM
Thanks for sharing that info. What is the diameter of the saner bar?
Anyway, I measured the bar length and then the arm length at the different holes, and this program tells you the results. It also has the capabilities to do roll centers, so we plan on doing that sometime over the winter.
I'll find out what the program is called and let you guys know...
