S2000 STR prep resource
Removing the rear bar makes the car push really bad. I have been tinkering year long with bars and same rate springs front and rear.
I am leaning towards running a smaller rear bar if I can locate one. as well as my front saner bar.
^ I agree. I have been running with no rear bar for several years with great results. I prefer a very loose car. If you are having too much understeer with no rear bar and equal spring rates, I suggest you look at alignment or a lighter front bar. Are you running a bunch or rear toe in or a large front bar?
I know you aren't referencing my post but I thought I'd throw this out there too - I'm running one of the largest front bars available (1.44") and I have zero issues with understeer (unless I induce it by jackassery).
With a large front bar as used for autocross (i.e. 1.44") the car is much better behaved (balanced, do what you want it to) with the same size tires on all corners. A staggered tire setup tends to exhibit understeer.
Questions about shocks:
I am decently knowledgeable adjusting a cars settings day to day/event to event.... but very new to building a car from scratch.
For shocks, does the typical AS S2000 Koni valving translate well to STR and higher spring rates? I don't know the fine details of the typical AS valving so I am not sure if there is anything weird about it to accommodate stock spring rates.
I've never custom valved shocks and will be looking to make a purchase of Koni DAs for STR in the next month or so.
I've never seen the valving of an OTS Koni but I run my revalved Koni's at near full soft. No need to try to use rebound anymore to control body roll like we did in AS.
I have a set of revalved-and-converted to DA koni's on my FP car. I had them rebuilt this April and revalved to handle higher spring rates. I've been experimenting all year with springs ranging from 700lbs to 1200lbs, and they work very well, although I have been kicking around the idea of selling them and trying something new.
Originally Posted by vehicular,Oct 5 2009, 02:37 PM
Elaborate, please.
Actually, its pretty hard to run inverted front shocks because the sway bar is in the way.
