S2000 STR prep resource
Old Jan 31, 2011 | 04:49 AM
  #3341
dnace's Avatar
Originally Posted by Random1,Jan 31 2011, 12:04 AM
Most people just make their own out of the silver bubble wrap insulation.
I have been looking for a roll of that, where do you guys find it?
Old Jan 31, 2011 | 05:36 AM
  #3342
josh7owens's Avatar
homedepot or lowes over in the insulation area.
Old Jan 31, 2011 | 05:39 AM
  #3343
captain_pants's Avatar
Home Depot - it's often used for insulating hot water tanks.
They are very easy to blow away though. I end up wedging shoes between them and the top of the fender to keep them in place.
Old Jan 31, 2011 | 10:47 AM
  #3344
alvanderp's Avatar
Originally Posted by SC_Highlander,Jan 27 2011, 12:45 PM
Steve won DP, no DSP. I have been running my FP car with no bars since the first event after Nationals. I'm a fan, but I'm also running far lower spring rates than his math would suggest.
He's won DSP multiple times as well, prior to getting into the DP MR2.
Old Jan 31, 2011 | 12:50 PM
  #3345
dnace's Avatar
This isn't the same stuff that has the sticky backing is it? I have used that to cover my intake heat shield
Old Jan 31, 2011 | 02:08 PM
  #3346
Orthonormal's Avatar
There is probably a sticky-backed version available, but this stuff comes in 2 foot wide rolls with a thin aluminum coating on both sides, no adhesive. Cut it to the right shape and hold the seams together with duct tape.
Old Jan 31, 2011 | 06:44 PM
  #3347
pinkertonpunk's Avatar
For those of you with Motons that are looking for another option on top hats the AST ones fit perfectly. I ordered some about 4 months ago and they are finally here. You have to use the Moton bushings for inside of the bearing but otherwise they fit like they were made to go together.
Here is a crappy picture:
Old Jan 31, 2011 | 06:59 PM
  #3348
Random1's Avatar
Originally Posted by josh7owens,Jan 31 2011, 06:24 AM
Alot of the "pre-made" ones are really thick and some cant get them on the rear if the car is really lowered. I would just make some.
You must be thinking stock class Corey. I can barely get a water sprayer nozzle over the top of the tire. We ended up doing the car wrap at nationals. If you have painters tape it works reasonably well to keep it in place and from blowing away. Having friends in grid to help out is recommended.
If you can only get the 4ft roll it can be cut in half with a saw before taking the wrapping off.
Old Jan 31, 2011 | 07:18 PM
  #3349
macr88's Avatar
Another pic with the Ohlins pin mount.
Old Jan 31, 2011 | 07:41 PM
  #3350
robinson's Avatar
Nice hardware!
