S2000 STR prep resource
My RS3's almost have no tread left right now, and I have determined for sure that they need to be really cool. I experimented with different temperatures (unfortunately my thermometer was out of batteries so subjective) and found that they performed best throughout the run when they were warm to the touch, but not at all hot, like maybe 100 degrees. If they were hot at all then they would feel greasy by a couple turns in.
I was thinking about it and they weren't this way before - I didn't even bring a real water sprayer until now. So my theory is when they get near the end of the tread it's a little different compound that really doesn't like heat.
Now I'm really not sure what to do about tires. For next year I'd like to have the RS3s as well as a cold/rain tire (probably dunlops), so I'm thinking about getting those cold/rain tires now if I can find one that's decent in normal conditions too like the dunlop. I'm not doing nationals so I've really just got one autocross per month from now through october, and probably everything past the next one will be cooler.
So here's a question. I have 3.0 degrees camber up front, 2.1 in the rear, aka really high since the hankooks like that. How do other tires do with that alignment? I'd like to be able to swap back and forth depending on if it looks like it might rain or be cool, without realigning. I'm also considering those yokohamas instead of the dunlops for cold/rain tires, but I have no idea how they'll compare. Knowing that they can't deal with heat is helpful, but if I'm using them as cold/rain tires they might be good. Hoping I get the next issue of GRM soon, haha.
Originally Posted by Random1' timestamp='1310943319' post='20788521
Although they only come in 245R17/40, has anyone tried Yokohama ADVAN Neova AD08s? Any opinions? They are the same diameter as the R-S3s and the width is 0.2 inches narrower according to specs on TireRack web page. A friend has run them on his Evo and liked them a lot other than the cost which is $205 each. He said the side wall is firm and provides great response compared to R-S3s and even Star Specs.
Obviously at $500 per set the R-S3 is be the best value going for the S2000.
I actually hit 169deg on the RS-3's on my friends BMW and boy they started to change eek. Will not let them get this hot on the s2k.
As to your camber question, I can't say definitively. Dunlops and Yoks will have similar camber preferences, due to their stiff construction. The Hankooks will run at lower camber numbers but I haven't determined what the ideal camber range is for the Hankook and what time is lost out of the happy place. If you are trying to keep the tread flat under load, wear indicates it needs more camber. Pyros are telling me they work with roughly the same camber as my Dunlops, however. -2.6F/-2.4R on concrete had the inner shoulders 5-10*F hotter than the outer shoulders.
Has anyone run Bridgestone Re-11? I was thinking about them for next year. Autocross season starts around March here in the North East. No fun running RS-3 until June. So it's like 3 months of frustration of not getting enough heat on the tires. From research they are pretty good around 50 degrees, just worry they will overheat in 90 plus summer temp.
Weight difference between shortened Bilstein PSS and Penske 8100 (dampers only) -
Bilstein front with 8100 canisters = 7.44 lb
Penske8100 front = 4.55 lb
Penske8100 rear = 3.76 lb
Will weigh the Bilstein rears when they come off. Not much of a difference, just thought I'd document it.
Originally Posted by dnace' timestamp='1311095680' post='20793954
[quote name='Random1' timestamp='1310943319' post='20788521']
[/quote]
128i super quick turn around in the heat and that was after a re-run that I did not get 5min. ground temp was around 120 something
