S2000 STR prep resource
Old Aug 15, 2011 | 10:31 PM
  #4471
Random1's Avatar
Originally Posted by IntegraR0064
Originally Posted by glagola1' timestamp='1313442878' post='20880413
I've run up to 9/16" toe in and the car just got tighter. I don't think you have too much toe in.
That's on an AP1 though right? And on dunlops? I think rear toe is one place where the AP1 and AP2 differ. You didn't run anywhere near that much when you had the AP2 right?
Just a reminder of the rear ride height and it's affect on toe steer. See prior post on May 3, 2011 12:57PM quoted below.
It's not apples to apples from one car to the next depending on static ride height and AP1 vs AP2 when describing rear end behavior.
Next time I take my shocks off I will measure rear suspension height (hub center to fender edge) vs toe.
Originally Posted by Random1
Originally Posted by ///MIKE' timestamp='1304436194' post='20532811
snip...
My other question was regarding the AP1's gaining toe-in in the rear when under load? I think I read that somewhere in the last page or so.. Is that really the case? When I lowered my car, and didn't do a re-alignment, I gained a whole bunch of toe-OUT (AP2). I'm curious because this is the first I've heard of this. Is this an AP1 exclusive due to different suspension geometry?
Gaining toe out as you lower your car makes sense. If you keep lowering it eventually you may get toe in.
I could not find a rear toe curve plot, so I threw this together to help illustrate. The effect of this is similar for AP2s but the ride height will be different because they off set the control arm attachment point where it attaches to the hub.
The figure below attempts to illustrate the effect of rear control arm articulation on rear toe. The inner end of the control arm is attached to a fixed pivot point on the sub-frame. The outer end is attached to the front of the rear hub. As the control arm swings the hub end moves in an arc. The effect of the arc on the toe is all relative to the starting position. The static stock ride height places the control arm below horizontal. As the suspension compresses it pushes the front of the hub out (toe out). As the suspension rebounds it causes toe in. If the control arm goes above horizontal then toe in will occur.
If the car is lowered and the static ride height places the control link above horizontal the compression will cause toe in and rebound will cause toe out. The overall affect is opposite of what happens at the stock ride height.
Here's a photo of the rear control arm with the ride height set to 12.5" from hub center to metal fender edge. As you can see it's above horizontal. Any compression of the suspension from this point (like when loaded in a turn) will cause toe in to occur. Provided your driving is smooth (i.e. don't have sudden throttle lift mid corner) then the toe in (rather then toe out) makes the back end more stable. This setup up also slows down the initial corner turn in which also helps reduce the chance of over steer.
To achieve such a low ride height (12.5") you will need really short rear shock bodies and appropriate spring rates! At this point my suspension dances around the end of a shortened bump stop under most conditions (no nasty bumps).
EDIT
One more thought regarding the static toe setting... you can start with less static toe, but beware that under braking this could cause toe out resulting in an unstable (squirrely) back end.
Old Aug 16, 2011 | 01:58 PM
  #4472
josh7owens's Avatar
Serious question-
How does one get sub -2.4 degrees of camber in the rear with our ride heights?
I think it was random1 that posted the other day saying somthing about -2.1 in the rear. It might of been someone else, I dont know. I couldnt get less then 2.4 today on the rack.
Old Aug 16, 2011 | 02:45 PM
  #4473
robinson's Avatar
If you have SPC in the rear, you can reverse the direction of the ball joint. That should work.
Old Aug 16, 2011 | 03:24 PM
  #4474
josh7owens's Avatar
That's what we thought about at the shop but didn't know if anyone else has done that since I've never heard talk about it.
cheapest place to buy spc ball joint?
Old Aug 16, 2011 | 03:29 PM
  #4475
mLeach's Avatar
Offset bushings in the rear. You can also use these in the front if you don't want to use the J's/Hardrace ball joints.
Old Aug 16, 2011 | 03:46 PM
  #4476
bronxbomber252's Avatar
I am at -2.2 in the rear, with no aftermarket alignment help in the rear... It just went there no problem on the rack...
Old Aug 16, 2011 | 05:01 PM
  #4477
josh7owens's Avatar
Wierd, I'm debating buying all new A-arms over the winter but it's $1569.18! I prolly should just get the poly bushings but I hear some people dont like them because the deform over time which causes play in the bushing. Bushings are in the $600 range but requires alot of work to install them plus I'd still have to buy the front lower a-arms because of the caster bushing can't be replaced. Which are $252 each, totaling $1052 after bushings.
A couple of my eccentrics are very hard to turn but they are at mininum on the back eccentric and we used the front eccentric to get the toe I wanted in th rear. Sucks we ended up at 2.4X in the rear.
I'll prolly order the spc ones unless someone links me to rear upper A-arm offset bushings.
Old Aug 16, 2011 | 05:46 PM
  #4478
User 121020's Avatar
Originally Posted by josh7owens
...plus I'd still have to buy the front lower a-arms because of the caster bushing can't be replaced...
Don't know anything about these, but saw this link in the suspension forum the other day - Polybush: S2k front lower control arm, rear bushing.
Old Aug 16, 2011 | 06:18 PM
  #4479
robinson's Avatar
FWIW, I got four used upper a-arms with ball joints for $150. The used market is great!
Old Aug 16, 2011 | 07:45 PM
  #4480
Random1's Avatar
Was not me regarding 2.1 in the rear. I run 2.5 and have not tried out the minimum setting.
Why do you want to buy new new A-arms or bushings?
BTW Mugen makes replacement bushings for the front lower A-arms (http://www.gotuning.com/product_info...roducts_id=873). I believe the removal process is to cut out the rubber and then cut the metal insert to pull it out. Installation is done with a press.
