S2000 STR prep resource
Old Sep 7, 2011 | 07:55 AM
  #4551
sirbunz's Avatar
Originally Posted by rjones
Has anybody tried the Toyo R1R on the S2000? Looking at Nationals results the Toyo owns ST and STS but very few people in other classes run them.
For the people that have tried them what did you think? I am thinking about using them for rain and cooler events, but not sure if I should just stick with the Dunlop star specs.
The 195/15 RS1 is a much better tire than the rest of their offerings. With the other tires they use different compounds to help firm up the tire. Glagola ran the 255/40/17 R1R fro a season of his AP2.
-Marc
Old Sep 7, 2011 | 08:15 AM
  #4552
762's Avatar
762
Originally Posted by glagola1
Right now, my car is predictable and easy to drive. ugh...
Well if it's easy to drive, predictable, and fast (based on nats results). Maybe suspension alone is not the answer for speed at the moment. Perhaps more power, a differential to put down the power (which might result in a new setup to work with the diff) or added lightness is the current step?
Also it makes sense to me that the kooks may not like the massive (ie.. gendron 1.375) front bar on full stiff. With their softer sidewalls it seems reasonable to figure that the faster loading of the tire makes the tire deform faster. Kind of in the same way that the cars running kooks seem to employ more camber then cars on Dunlops.
Old Sep 7, 2011 | 08:49 AM
  #4553
imstimpy's Avatar
Originally Posted by fsmtnbiker' timestamp='1315345403' post='20948598
Melchior's AP1 has a stock diff (for now)
Setup related:
Throughout the season we have found that increasing roll stiffness has made the car not handle/feel as good for either driver. When we went to a solid 1.25" element and the stock AP1 MY00 bar, the car was very well balanced, but neither end of the car was ever "planted" (subjective). It felt like you could overdrive the front or the rear very easily. When we went down in roll stiffness and up in spring rate to keep the total roll rate close, the car got more driveable, and more driveable on varying surfaces. Total grip seemed to go up as well, but I don't have any data to back this up.
See, it's interesting that I have the opposite observation and I have been running Dunlops exclusively. Perhaps the Kooks don't enjoy the fast loading of a big bar set up? It's annoying comparing set ups now that I've developed the car on Dunlops due to the Kook shortage. I just can't imagining having to soften the roll rates to accomodate a tire that is sloppier than what I'm running currently. Right now, my car is predictable and easy to drive. ugh...
This. I've wondered if it has to do with driving style where the Hankook has a very fat slipangle. I use the tires interchangeably, chosen by ambient temperature. I'm known to be slow to adapt to newfound grip though so my A/B may not fully utilize the extra grip of the Hankook. They feel like ass IMHO, but are fast.
Here is my setup:
Settings (F/R) Me (MY06)
Shocks Moton Clubsports
Compression 4/3 @185psi
Rebound 3/4
Anti-roll bars Gendron bearing 1.25"x0.25" @6/stock
Ride-height 13.0"/12.9"
Springs 850#/700#, 7"x2.5" + helpers
Toe 0"/0.25"
Camber -2.6*/-2.4*
Tires 255 Hankooks @36psi OR 255 Dunlops @36psi
Differential stock
Power intake stock, exhaust T1R 70-R-EM SS, 37805-PZX-A080-M1-COBB_R8500_V5500_VEH_IH.hex
I do have a spreadsheet with a few other setups, including a lot of math, but others' setups are helter-skelter since very few post all of their setup. I can share it if anybody is interested. I'm sure it will be rapidly reproduced with people sharing them within the thread.
Old Sep 7, 2011 | 09:43 AM
  #4554
mron0903's Avatar
Hey guys, I've been reading through as much as I can for this thread but I have some questions. I've noticed that as far as alignment goes, seems like you guys don't generally run any toe-out in front but some toe-in for the rear. Any reason not to run toe-out in front? For general alignments on RWD cars I've seen toe-out to be a good thing to help turn-in. Forgive me for such a noob question, but I am curious as to why? I'm not new to autoxing but I am new to STR prepping, been doing a lot of research as to how to set up my S. Thanks!
Old Sep 7, 2011 | 10:02 AM
  #4555
glagola1's Avatar
Generally, the S2000 turns in like a mofo so there isn't much to be gained from toe out and too much toe out in front can cause push at mid corner.
Old Sep 7, 2011 | 10:06 AM
  #4556
imstimpy's Avatar
Originally Posted by sirbunz
[i]For Nationals we tried the following. (If not listed, its stock)
-Ohlins TTX Shocks on 700lb front/500lb rear springs. Shocks initially set in the middle of 25 clicks(12/12, 12/12) We tried adjusting but induced some push.
-Rear swaybar removed
-Gendron 1.375 Front Sway set at 3/6
From here, We decided to make the following changes, toss this setup, and start over...
2. Lower the rear ride height slightly. I have no height #s, but we were higher than most at Nationals. Initially, we lowered the rear as much as the shocks would allow, but its still too high. We set the height of the front higher to compensate. To lower more, we have to modify the top perch of the shocks to allow for more suspension travel. We may have to work with the shop we bought them from on this as they already offered.
3. Increase the front spring rates. We haven't made a final decision on a number, but looking at the pictures from Nationals, the front has way too much nose diving going on.
-Marc
RE: 2. and 3.
Nose dive can come from many factors, including: front spring rate, front compression, rear rebound, ride height, and rake. You have a lot of front roll bias and little rear so I'm not sure a front-only spring change is the direction you'd want to go. I'm not sure I've felt like my car has experienced too much nose dive at any rates I've run including 700lb front. Just trying to provide some more options. Forgive me if you have thought about all of this already.
Old Sep 7, 2011 | 10:12 AM
  #4557
glagola1's Avatar
Jon, keep in mind that the Ohlins probably don't have nearly as much low speed compression as the Motons do so that could explain away some of the dive you've never noticed.
Old Sep 7, 2011 | 10:46 AM
  #4558
rjones's Avatar
-Marc
Thanks 762 and Sirbunz. What you guys said goes along with what I thought. Looks like it's Dunlop's for rain, and cool weather unless someone has something good to say about the Toyo's.
Old Sep 7, 2011 | 11:32 AM
  #4559
mron0903's Avatar
makes sense, but what about doing 1/8th toe-out in front and 1/16th toe-in the rear?
Old Sep 7, 2011 | 11:44 AM
  #4560
Random1's Avatar
If you actually drive your car on the street the front tires will be eaten up very quickly with any toe out. I know some that do change it at events, but it's really not needed. The S cuts like a knife! If you have understeer then there is something generally wrong with your setup (to stiff up front).
It's fun to watch someone drive an S2000 for the first time and see them make two turns for the first several. The first turn ends up to early, then correct and then turn a second time to get around the cone. Otherwise they hit a bunch of cones.
Rear toe is really a personal preference and used to control how loose the car is in general.
