S2000 STR prep resource
Well now that nationals is over and we are talking about set-up for next year. (Already upset I missed this year, stupid law school.) I figure I should post these up for comment.
This is my e-manage ultimate tune with a K&N FIPK and Berk 3 inch exhaust with HFC.
The dyno was before and after the tune (the gains from the parts are already visible on the before tune). Also the dyno was done in 100 degree weather so that dampened some of the gains as well. This exhaust is right at the 100 db range and I will be getting a muffler or some solution
UMS Tuning in Phoenix did the work and said it was one of the stronger bolt on S2Ks they have seen, but that because DBW/Hondata gives more precise control of all the parameters including ignition/fuel the tunes for those cars normally show a marginally bigger increase. Either way with the emanage tune the 2005 is much closer to a tuned 06+ and feels like a very different car in the mid-range.
The one event I have done here in Tucson in the car with the tune had my times right around Random1 (also in the region). I have not really made to many setup changes from last time I posted my info besides setting the car a touch lower and corner balancing.
The car currently seems faster then I am so I just drive it. If I could make any changes I think it would be to increase spring rates, with the rear increase greater then the front. As in some sweepers it is just a touch pushy.
Does anyone want me to create a joint spreadsheet with people's setups on it? We can do it via pm/email to make it that the only way you can get access to the information is if you share as well. Also this could create a generic format so that as people update there setups it is easy to keep track of it.
For Nationals we tried the following. (If not listed, its stock)
-08 CR delete
-New/Full Tread 255/40/17 Hankook RS3s Square on 17x9 Enkei PF01s
-Ohlins TTX Shocks on 700lb front/500lb rear springs. Shocks initially set in the middle of 25 clicks(12/12, 12/12) We tried adjusting but induced some push.
-Alignment, -2.8 Camber front, -2.4 Camber rear, 0 toe front, 1/8 toe-in rear, 7' caster
-Rear swaybar removed
-SPC upper ball joints
-Gendron 1.375 Front Sway set at 3/6
-Berk Header, Berk HFC, Flash Pro, Tune
-Modified stock exhaust (we did get tagged at 97db!)
-Full+ tank of gas
-No other weight mods
From here, We decided to make the following changes, toss this setup, and start over...
1. Most important ... more seat time. We plan to attend Blytheville and Nashville as well.
2. Lower the rear ride height slightly. I have no height #s, but we were higher than most at Nationals. Initially, we lowered the rear as much as the shocks would allow, but its still too high. We set the height of the front higher to compensate. To lower more, we have to modify the top perch of the shocks to allow for more suspension travel. We may have to work with the shop we bought them from on this as they already offered.
3. Increase the front spring rates. We haven't made a final decision on a number, but looking at the pictures from Nationals, the front has way too much nose diving going on.
4. Since we will need to re-align, we plan to add more rear camber.
5. Install the ball bearing mounts from Gendron we picked up at Nationals. This will make minimum differences.
6. Set the shocks at 0 and begin driving.
-Marc
If you keep chasing after that perfect setup and never get much seat time with a particular setup, you are at a big disadvantage against those who do.... snip... Once the major components of your setup is there, do yourself a favor and just drive it for a while. You need to make youself drive around your setup because its never going to be perfectly suited for any course no matter how hard you try to toy with it. I think we need to reiterate that blaming your setup is only going to be recieved as making excuses.... snip...
Josh, you will regret changing cars. The only difference between me and the top drivers in STR is driving skill and experience. Get your car to a place that you can drive consistently and work on seat time. I can't emphasize enough how important seat time in a car that does not change between events. I only had two events in my current setup and my times at Nats showed.
-Dave
-Dave
I on the other hand, need as much seat time as I can get. I wasn't used to the surface, and I wasn't used to the additional power (I'm normally a mile high).
Ok, I have finished making the googledoc currently with my setup and the template form.
I know it is tedious having to type everything up but the googledoc has many advantages in doing it this way.
Through googledocs the information of everyone is viewable from anywhere and is always compiled/update.
If you want to get on the googledoc email/share list please send me a pm with some substantial info that way I know you are serious, and I also need you EMAIL ADDRESS without the email address I can not add you to the sharing list.
The Stock setup FAQ has had 59051 views. Hiding the equivalent information for STR will just prevent thousands of people of benefiting from it, which will only hurt the car and the class.
Discussion and the like would still be visible here. If anything the sheet works as a quick reference to people's setups. For example if Josh discusses a handling problem, I can now, instead of digging through several 100+ pages to find his most recent setup I can easily pull up the document and look at it before making a comment here.
I do not want to move discussion from this forum, and the googledoc does not really allow that anyway. Instead the spreadsheet is simply an easy reference.
Also if people would prefer, I can put the link up either here or somewhere else and open up the security so that anyone can view it.
Here is my setup at Nationals:
Moton Clubsports
750 front springs/ 650 rear springs
1.250" hollow front gendron bar set 3/6
Rear MX5 bar
Ride height is about 12.75"F/13"R (about)
Alignment was -2.8F/-2.5R camber, max caster (about 7) and 0 toe front and 1/8" in rear
Full delrin busings, offset front upper control arm bushings to add camber
OS Giken differential
T1R 70R EM-Limited
Hondadata reflash
255/40/17 RS-3 on 6ULR wheels
I think that is all the info that would be needed. Always more than happy to share. Love to compare notes on cars so I think this is a good idea.
Moton Clubsports
Rear MX5 bar
T1R 70R EM-Limited
Hondadata reflash
