S2000 STR prep resource
I looked into it, and I think that it was just due to the bumpy lot and the car possibly turning. If found another picture from the event, and it looks higher:
http://picasaweb.google.com/atlantamx3/200...729555489780706
The Penske shocks on the car tended to keep the car low, and we it even tended to bottom out on the fenders in the front.
-Brian
-Brian
-Brian
-Brian
Yeah for the most part if you run off the shelf Penske's from SRP - you've got about 700lbs of rebound force at 3in/sec on a HALF STIFF setting. Setting it full stiff gets you to 700-800lbs right around 1.5in/sec
How the hell can the suspension even extend if you've only got 650lbs of static corner weight? (read - when you transfer load off that corner to make a turn - its more like 300lbs of load on the tire and the shock is actually compressing the spring...)
Originally Posted by CKit,Nov 24 2009, 08:06 AM
I still think when people start getting experience with 1.5-way clutch-type diffs it's going to be one of the "must have" modifications.
When we switched, the difference was marked.
I love the way my s2k feels under braking, and I generally like open-ish diffs, but I'd like to hear someone's opinion that has experience making the switch.
