S2000 STR prep resource
Old Jan 2, 2011 | 04:04 PM
  #3141
IntegraR0064's Avatar
Originally Posted by TheNick,Jan 2 2011, 03:58 PM
Depends on how it is shown in accessory catalog.
If you go to the Honda Estore (estore.honda.com) and click on 2006 S2000 - there are specific instructions on how to install a "wing spoiler" - part number 08F12-S2A-1J1.
It doesn't appear as if the CR wing is actually orderable through this website as an "accessory" though.
Yes you can order that spoiler through their catalog - but that's not the CR spoiler, that's an accessory spoiler. The CR spoiler part number is 71701-S2A-A012C (for berlina black as an example).
And the trunk lids are different part numbers for the CR and non-CR. So maybe you can't use the CR spoiler. I'm assuming the "if it bolts right up in the correct way you're good" rule doesn't extend to buying a CR trunklid and spoiler together.
Old Jan 2, 2011 | 04:36 PM
  #3142
misterwaterfallin's Avatar
Those of you guys running Koni's, how much did you cut the stock bump stop if any? Im reusing it obviously, and believe I need to cut it down but Im unsure of how much to cut
Old Jan 3, 2011 | 07:47 PM
  #3143
stantaur's Avatar
Originally Posted by Random1,Dec 21 2010, 11:02 PM
^^^ LOL
Bye bye spoiler... fun while it lasted... anyone know someone in XP or CSP that needs a spoiler (cheap!). I've already been running without it for the last few months. Sway bar and spring adjustments appear to be working reasonably well.
Yeah, six small screw heads with o-rings for sealing on my trunk will remain for a while until I find a silver replacement.
Nice wing. Can you PM me the dimensions / shopping list of materials please? Might be nice to add it to a spare decklid given the infestation of tri-rotor FD RX7s running $$M in TX/AR/OK...
Thanks,
Stanford
Old Jan 4, 2011 | 09:52 AM
  #3144
762's Avatar
762
Well I finished painting the wheels last night, and this is the result. I love the color, very gulf racing-esque which is kind of a theme I am going with. However, close up the paint did not really come out as good as I have done in the past. Either way I think it gives the slightly bland TR wheels some extra visual assistance.
I thought I had a line on a Saner front bar yesterday but that fell through and it looks like the gendron may be the only in stock option available. What stiffness/size option does everyone seem to like for STR?
Old Jan 4, 2011 | 10:06 AM
  #3145
robinson's Avatar
Mine are cut down to less than a 1/2 inch.
Old Jan 4, 2011 | 12:09 PM
  #3146
awesome thanks! Mine should be going on soon, not that it matters because it barely gets above 30* around here it seems and the roads are all iced
Old Jan 4, 2011 | 01:48 PM
  #3147
josh7owens's Avatar
I have the solid 1.25" bar. A local has the 1.375" hollow bar and uses it on full stiff but to "some" that might be over kill. In my opinion the hollow 1.25 would be to soft and you should opt for the solid 1.25"
A wise man told me "If your rear inside wheel is lifting in a turn add more front bar, If it's not, soften it up until it does, then go one notch stiffer" , "you want to use the front bar to stop from lifting that inside wheel and causing traction loss"
I love the slolam feel of my front bar on full stiff but if you don't set up early for the turns and really ask alot from the front tires it will "push" and "understeer". Get set up early and get that car rotated it will feel very stable and fast but it doesn't always work out right.
I'm changing my whole set up this season though. I'm going to try less bar but I don't know how its going to play out. A local T2 driver that has alot of track records in a S2k told me "you autocross guys need to get away from that stiff front bar, its doing nothing but hurting you" and I just reply with "But it feels so stable and transitions so fast". You can't really compare track racing to autocross and stiff seems to work in the autocross world.
Although, I know nothing and just a parking lot racing, JDM'ed out, ricer.
Old Jan 4, 2011 | 02:20 PM
  #3148
762's Avatar
762
What are your current spring rates?
Old Jan 4, 2011 | 03:18 PM
  #3149
josh7owens's Avatar
700f/700r when I had my shocks on last year only because that's what came with my used jrz coil overs. I'm going with 850f/700r this season with my solid bar on the front and a miata bar on the rear. I'm going to try to "like" the 4th stiffest setting because that's what my bench racing exel sheet "tells me" to run but well see how it works out.
Also
2.6 camber front with 0 toe and 2.3 camber rear with 0 toe.
Thenick and people like that are 100 times more nolegable then me about tuning and settings and such. So don't take anything I say to serious.
Old Jan 5, 2011 | 02:59 PM
  #3150
sirbunz's Avatar
I agree. Too much bar hurts you. I would much prefer making alignment changes vs. stiffening the sway bar. It takes too much bite away from the front end. If you can't dive and hold on to the tight line in a turn, you might as well pack up and go home.
Also, wheel lift happens no matter how stiff you go. We race on bumpy lots so eventually you will get an uneven surface.
-Marc
EDIT ... Fixed a number of my errors
