S2000 STR prep resource
Old Feb 3, 2010 | 08:12 AM
  #1121
Suspension's Avatar
Ok, Matt, I see your point. Are you talking about repeatability and hysteresis that don't show up on a dyno plot?
Old Feb 3, 2010 | 08:13 AM
  #1122
TheNick's Avatar
Originally Posted by Suspension,Feb 3 2010, 11:56 AM
If I can get the exact same damping curve out of a less expensive damper, valving design differences go out the window - unless you can argue that the Moton will be more consistent due it it's valving design.
I was just inquiring (don't want to start an argument) to see if there was proven information that the Motons:
a. have more consistent damping due to lower hysteresis and/or larger oil volume/gas pressure and/or valve design
b. have a wider range of adjustability
c. will last longer due to better seals and tighter tolerances, etc.
I can't say which is better than the other, just trying to gather information. I have a Penske damper rebuild specialist and dyno 100 feet from my desk, perhaps I should look in to Penskes and get back to you guys.
edit: one more thing, the Moton's 22 mm piston diameter is pretty small, I believe. I've seen values for Koni yellows of 25 mm, but don't quote me, I am still looking.
I'm not talking about consistency - I'm talking about design - we all know that what shows up on an FV curve is only part of the game.
Here's just a little part of it.
Moton uses Bypass and Blow Off valves to mitigate the transition from Low to High Speed damping. They then use multiple levels of shim stacks with spacers and very low preload. They use thicker shims to get the high speed damping, instead of preloading thinner shims. The shims have a progressive spring rate, if you preload them - they lose the initial soft spring rate and go straight to the harsher rate. When you blow off at the knee of the curve, the shims snap open very quickly. By using thicker shims and low preload - the initial soft spring rate is still preserved and the transition is much smoother.
Penske on the Digressive Piston, uses simply the piston and a preloaded shim stack to get their curves. I'm not sure on the Velocity Dependent or Regressive Pistons - I'd have to check with the manual.
So you can make a Penske look exactly like a Moton - but will it work the same? Maybe - depends on how the builder put it together. I believe that if they use the same concepts - then yes it will be close.
Not only that but the Moton uses a 22mm shaft that displaces more fluid under compression and leads to a different feel.
I do know that Penske's have to be rebuilt every couple seasons - the last set of Moton's that Matt owned had near 30k miles on them and looked brand new when they opened them up.
And yes I'm saying that Clubsports are not Stock Class legal unless you run a really long bumpstop in the front. The rears are fine.
The front bodies are 14.6" long and the stock bodies are 17.25" long.
Old Feb 3, 2010 | 08:20 AM
  #1123
glagola1's Avatar
Derek, I think you may be confusing the diameter of the valve and the diameter of the piston.
22mm is huge for a piston. Most companies use 14mm. If you are seeing a 25mm piston then I'm going to assume that's on a strut based car and odds are that the piston is actually the body upside down.
Old Feb 3, 2010 | 08:22 AM
  #1124
TheNick's Avatar
Actually - you have it wrong too
22mm is tiny for a piston - Penske uses a 55mm. When Moton talks about 22mm - they mean the shaft.
Old Feb 3, 2010 | 08:33 AM
  #1125
glagola1's Avatar
I don't see anything in the rules that says a shock body must be of a certain length. The fully extended length of the shock has to be within 1" of the standard part but that's all I see about that. It also states that bumpstops can be cut or substituted but the initial point of contact cannnot be increased. In other words, the shocks are completely legal.
  #1126
glagola1's Avatar
Oh.... When I said piston, I meant shaft. I'm definitely still learning but what's really interesting is that after being on Motons for 5 years (with a mix of Konis in there) I'm starting to see why what I've felt is true.
Old Feb 3, 2010 | 08:40 AM
  #1127
Suspension's Avatar
Ahh, that makes sense. Thanks for clearing that up. Yes, large shaft diameter is good, gets more fluid flowing through the compression valve in the remote reservoir. Thanks for all the info, Matt and Nick.
Old Feb 3, 2010 | 08:52 AM
  #1128
TheNick's Avatar
[QUOTE=glagola1,Feb 3 2010, 12:33 PM] I don't see anything in the rules that says a shock body must be of a certain length.
Old Feb 3, 2010 | 09:00 AM
  #1129
glagola1's Avatar
I don't think your interpretation is correct. What the rule is trying to do is prevent somebody from adding spring in the form of bumpstop.
"the compressed length of the shock at the initial point of contact with the bumpstop may not be increased..."
Take a "standard" shock with the bump stop installed. Compress it until the bump stop makes contact with the shock body. Measure the length. For example let's say the stock part is 24" tall when the bump stop makes contact. The Moton with it's shorter body will be 20" before the bump stop makes contact. 24" is more than 20" therefore 20" is not an "increase" over the standard part.
Get it?
Old Feb 3, 2010 | 09:04 AM
  #1130
TheNick's Avatar
Yeah I think I'm wrong
