S2000 STR prep resource
Old Mar 3, 2010 | 03:16 PM
  #1341
robinson's Avatar
Here is my solution to the left-rear-rebound-adjustment-clearance issue.
Glue has dried, and it works! I also left it on the shock, I don't think it's going anywhere.
Old Mar 3, 2010 | 03:40 PM
  #1342
glagola1's Avatar
Originally Posted by PossumK,Mar 3 2010, 06:44 PM
No unbearably loud bass resonance with the top up at 3-3.5k RPMs? I just swapped out a T1R 70EM Dual after only three weeks for a Mugen for several reasons, but I don't think I could have lived with it long term for fear of losing my low frequency hearing.
I guess it's kinda bassey but it's totally bearable. Now keep in mind, I used to drive a CRX with a straight pipe and a burns stainless muffler under my ass. This is a world of difference. I'm shocked how quiet it really is.
Old Mar 3, 2010 | 06:03 PM
  #1343
PossumK's Avatar
I bought one of these nut drivers and sawed off part of the handle to be short enough to fit in the trunk space but long enough to reach over the fuel line.
http://www.sears.com/shc/s/p_10153_12605_00941981000P
I believe it was a 5mm driver that had good enough grip on my Koni Yellow adjustment tab.
Old Mar 3, 2010 | 07:14 PM
  #1344
Random1's Avatar
That's cool. Below is what I made when running Konis in stock class. The socket is welded on so it stays in place.
The narrow handle allowed it to go past the fuel line boot and rotate. Your solution is much easier to achieve.
Old Mar 3, 2010 | 07:51 PM
  #1345
daverx7's Avatar
Ooooh... thanks for sharing this. I ordered this and will see if it does the trick. I currently have the stubby adjustment knob, but it is still a PITA to adjust my TC Klines (Koni DA's).
-Dave
Old Mar 3, 2010 | 09:13 PM
  #1346
PossumK's Avatar
Random1, I saw those pictures of your adjuster on some photo website and that gave me the idea of trying a regular nut driver since I didn't have any welding resources.
Dave, I used a socket set to verify the size of the nut driver needed before buying one. I'm not sure if the TC Kline Koni's have the same sized tab as the Koni Yellows.
Old Mar 4, 2010 | 04:00 AM
  #1347
Rodney's Avatar
Originally Posted by glagola1,Mar 3 2010, 04:34 PM
I just finished installing a T1R 70RT EM ....It doesn't have any highway drone and the sound at it's loudest is in lower RPMs.
umm, BS. i have 16k on that exhaust, and on the highway, especially pulling a trailer the pressure inside the cabin is fuggin excruciating..... get some miles on it, then we'll talk...
Old Mar 4, 2010 | 04:43 AM
  #1348
scareyourpassenger's Avatar
Originally Posted by glagola1,Mar 3 2010, 01:34 PM
I just finished installing a T1R 70RT EM and I have to say this is the nicest exhaust I've ever seen. It shaved 41lbs off the back of the car and it's 70mm.... and here's the kicker, it's totally a livable exhaust. It doesn't have any highway drone and the sound at it's loudest is in lower RPMs. I just can't believe I can have my cake and eat it too. We're lucky to have light, free flowing, and quiet-ish exhausts available.
Dang, I want one now
Old Mar 4, 2010 | 06:21 AM
  #1349
daverx7's Avatar
Fortunately, the TC's use the same knobs as the yellows, so I am good there.
Thanks again for sharing that info, it will make quick adjustments much, much easier! This might need to be in the FAQ's for the Koni's (both stock and STR) as that left rear adjustment is horribly tight.
-D
Old Mar 4, 2010 | 06:22 AM
  #1350
daverx7's Avatar
Me tooo!!! I am sure my dual Invidia's are still heavy compared to this.
