S2000 STR prep resource
Originally Posted by Ken Motonishi,Mar 8 2010, 10:16 PM
Sorta unrelated, but I drove an BS prepped S2000 CR yesterday (Pete Loney) on Kumhos and absolutely love that car. Stock shocks too. Pretty damn impressive car.
Originally Posted by sirbunz,Mar 9 2010, 07:23 PM
Yep, I too run "0" toe in the rear.
IIRC AP1 spec for rear toe in is 0.25" total and AP2 1/8". Someone correct me if wrong.
In the end it all comes down to driver preference.
I run 1/8" total rear toe in on an AP1.
Originally Posted by Random1,Mar 9 2010, 08:21 PM
AP1 is different then an AP2 as for dynamic toe in the rear, so not exactly apples to apples comparison. For AP2 they reduced the turn-in to not be as dramatic. Zero toe in the rear for AP1 could be touchy in high speed transitions.
Matthew's S2000 is an AP2 and why I threw the "0" toe comment out there. His springs and ride height changes may be causing unfamiliar issues as well. At higher track speeds, I absolutely would run more toe-in without the assistance of a wing. Still, I know some fast track guys in AP1s with "0" toe. I agree that it comes down to personal preference though. At this point in tuning the S2000 for STR, there is no proven method as of yet. I personally want to see more variety.
Matthew, any chance there isn't enough suspension travel with your setup? Rasing the ride height significantly helped one of the local guys.
-Marc
Originally Posted by Random1,Mar 9 2010, 06:12 PM
If you are resting on the bump stops that would create quick tire over load and loose rear end. I would raise the back end to test that or shorten the shock body before upping the front roll stiffness to fix the back end.
In fact, one of the ideas that I want to possibly test is to go a little softer (maybe higher too) on the rear and see if the progressive bump stops will help me get rid of some of the corner exit push while maintaining corner entry and transition stability.
RE: Toe. I ran 1/4" stock and thought that was too much. I thought 1/8" would be too little so I split the difference. Also, once you start getting into 700lb/in range, I wonder how much toe change I really have due to cornering.
It really all depends on your driving style. Up until Last year, I was running toe out in the rear to get the car to rotate more, but I found out that decreasing rear camber, and going back to 0 toe, I was bale to achieve similar results, so I went from -2.2 camber in the rear to -1.6 and 0 toe, and the car rotates, and is still very stable in fast transitions. That may not work for other driving styles though.
Ditch the bumpstops...if those suckers are as short as mine - there is no way you'll ever bottom them out and the bumpstops are just creating some inconsistencies.
I think I ran 1/8 total toe in when I was stock - it worked well with 2deg of camber. I had major issues with the car putting power down on Bridgestones though last year. So I went to 1/4" toe in and ran it like that for most of the season. Worked better, but still had to be very ginger with the throttle.
Thats the right way to do it.
A. It gets you more transitional stability in slaloms.
B. Its stands the tire more upright for ProSolo starts and corner exit.
