S2000 STR prep resource
Originally Posted by TheNick,Apr 6 2010, 07:34 PM
You never tried it with that little camber out back. If I remember correctly you started at 2.6 and still haven't backed it off much. I keep telling you man...
It has absolutely nothing to do with giving up grip. Its about moving more grip to another phase of the corner and holding/sustaining it there longer.
I don't know about you but I'd much rather have a car I can sustain 1.2g's all the way through entry, mid, and exit rather than one where I peak at 1.25g mid corner and then fall off on corner entry and exit.
Originally Posted by scareyourpassenger,Apr 7 2010, 09:02 AM
Wouldn't tire tempts indicate the right amount of camber? If it is more even then you know it isn't peaking on the inside or outside part of the tire.
Pyrometers are not all that useful, mainly because there are straightaways, braking zones and cool down time before you get back to your grid spot. I shoot for whatever camber gets me the handling balance I want. If it means more wear on the outside edge because I want more corner entry and exit grip, then so be it.
"After the run" tire temps should typically be 10-15deg hotter on the inside edge because of braking.
Originally Posted by glagola1,Apr 7 2010, 09:42 AM
Ahhh.... I see what you're getting at. Interesting. I'll have to do some testing on that... right after I figure out what tire pressures I should be running. I still don't know that.
Originally Posted by Random1,Mar 29 2010, 05:04 PM
Is anyone else getting a rattling sound from the rear axles after lowering? It can be heard when driving slowly (5-10 MPH) and going over small bumps. I don't have the vibration issue (inner CV cup wear spots) which is more typical of lowering a car with more miles on it. At first I thought the sound was something with the shock top hats since it showed up after installing the shocks/springs and lowering.
It was driving me nuts, but I recently found that I could grab the axles and shake them which sounds similar to going over bumps at low speed.
I can shake the axles on my friends stock 08, but they are not as loose/loud sounding as mine.
I have a set of spares that I'll try to install tonight... hopefully it'll be rattle and shake free for the tour this weekend.
