S2000 STR prep resource
Originally Posted by Random1,Mar 20 2010, 06:52 PM
Just got some photos of last weekends event. This one shows about the most roll I have seen from my car. The rebound/compression was very soft and rear bar was off. You can see the tires have a decent load on them.
That's quite a bit of roll or at least more than what I would think for that spring rate.
This is a video of my car with Bilstein PSS's 340f 285r and I was surprised that it doesn't actually lean more than it does
still trying to figure out what spring rate to run with these. I'm only running a CR front bar and stock rear bar. It wasn't a good auto x day for me that day
edit: fixed link
Originally Posted by macr88,Mar 20 2010, 08:34 PM
Is this with 750f 600r ?
edit: fixed link
edit: fixed link
Comptech FSB at 200% stock stiffness
Rear bar on
There are other factors (like tire grip) in how much a car leans, and it may not matter as long as the driver makes it happen.
I'd say your car is leaning more in this frame from the video.
Very true, I was on concrete and you are on asphalt, you may also be on stickier or wider tires as well and it wasn't a good day for me so I might not have been getting every bit of traction possible.
Originally Posted by Bikey,Mar 24 2010, 07:06 AM
According to the Tire Rack website, their TR Motorsport C3 wheel is available.
17 x 9 +62mm
19lb for the 17 x 9
Any reason not to get these?
17 x 9 +62mm
19lb for the 17 x 9
