S2000 STR prep resource
Old Apr 6, 2010 | 08:38 AM
  #1611
BrianGT's Avatar
Originally Posted by glagola1,Apr 6 2010, 11:22 AM
What if you welded in a nut for the stock seatbelts to bolt into just like they do on the stock hoops? I'd say that's not "removing".
You can't remove the stock hoops, so I don't see why this is necessary.
The Harddog roll bar lets you keep all of the stock parts during installation:
http://www.bethania-garage.com/s2000_install.htm
Old Apr 6, 2010 | 08:44 AM
  #1612
dnace's Avatar
yeah I specifically got the harddog so I could keep the interior and be legal for STR. Its not a big deal to keep the factory seat belt. I just have the potential to remove it at this point and wanted to be sure.
I noticed there was the call out in the prepared rules for restraints so I assumed I had to keep it but figured I would ask.
Old Apr 6, 2010 | 09:21 AM
  #1613
juice04's Avatar
What do you guys think of Corner Balancing? Is it worth the effort? Is it a point of diminishing returns?
Old Apr 6, 2010 | 09:27 AM
  #1614
///MIKE's Avatar
What are people running for Camber Front and rear? Specifically with the ideal offsets, ideal rim width, and ideal tire size 255's (62-63mm and 9" Wide).
I've searched for STR and Camber.. but I'm finding just a lot of "Will this fit if I have 8" wide wheels and +45 offset...etc"
So, basically, has anyone actually setup an STR car proper? I found a MX5 Miata that lists it's camber... and ironically has almost my identical setup... but it's a Miata.
Old Apr 6, 2010 | 10:05 AM
  #1615
Rodney's Avatar
no other way to install coilovers....
Old Apr 6, 2010 | 10:26 AM
  #1616
TheNick's Avatar
2.5-2.6deg front camber. Rear camber no more than 2.4. Tune rear camber to your driving style and hand speed.
Old Apr 6, 2010 | 11:08 AM
  #1617
robinson's Avatar
FWIW, I have 2.5 front and 2.0 rear.
Old Apr 6, 2010 | 11:26 AM
  #1618
an2ny's Avatar
I need to get some new engine mounts, I know that this topic was mention on page 36, but there was no real clarification of the rules. Can we replace the stock engine and transmission mounts for something like innovative mounts that are a bit harder than stock?
Old Apr 6, 2010 | 11:45 AM
  #1619
glagola1's Avatar
FWIW, when I installed my shocks, I set the spring perches to the exact same height on both sides of car. When I corner balanced the car, I didn't need to make any modifications. The car is 50/50 with out a person in it. When you get in, all the weight is on one side and it's balanced between the front and rear wheels so there's nothing more you can do to get it more balanced.
Old Apr 6, 2010 | 12:53 PM
  #1620
BrianGT's Avatar
-2.0 front, -2.1 rear with zero toe all around.
Once I am able to get offset bushings for the front arms, we will try more, as our front camber is maxed out, and the rear is at the minimum setting.
