S2000 STR prep resource
Originally Posted by BrianGT,Sep 28 2009, 09:01 PM
aside from heatsoak issues. I was thinking about putting some insulation around it.
I have a hard time believing that the increase in filter element area and the minor decrease in airbox volume could have made any significant power difference at all, but.....
Originally Posted by TheNick,Sep 29 2009, 12:19 PM
Awesome. You will definitely win if you do that
All I know is that when I went from the stock box to the K&N FIPK - I had to start planning for the cam crossover because the balance of the car would significantly change as it came on cam. This was especially hard mid-slalom.
Now that I've lowered the crossover - this scenario is completely gone
^^ hmm.. that is interesting. Do you have any before / after dyno plots? It doesn't seem like an intake is really a bang-for-buck mod for this class when people are claiming 1-3 hp gains, but what you're saying argues otherwise.
I didn't claim that it made more power. I just said the crossover had a significant change in dynamic balance of the car when the intake was installed.
I'm not claiming to be making more power with the lower VTEC point either - just thats its a hell of a lot easier to drive this way.
Originally Posted by vehicular,Sep 29 2009, 01:49 PM
You can't run a test pipe in ST. Your emissions systems have to all function.
Originally Posted by josh7owens,Sep 29 2009, 03:13 PM
I thought i read in the rules that you can change out the cat? which to me would mean you can run a test pipe with a cel fix?
I'll copy/paste this for you.E. Catalytic Converters ST, STS:
Catalytic converters may be replaced by aftermarket units. Replacements must:
1) Be certified for use in that vehicle application by the manufacturer or reconditioner,
2) Bear correct EPA-mandated labeling,
3) Be of the OE quantity and type (i.e. oxidation, three-way, etc.) and
4) Be used in the same location(s) as the OE converter(s).
This does allow for high performance replacements, provided they meet all restrictions herein.
you cannot tamper with the emissions system at all so no CEL fix or O2 fowlers allowed.
